Latest: heikkisj
Overall: 17126
Online Now [49]:
Visitors: 48
Today: 7208
Total: 100204866
Forums › The Car › 206 Talk › Haynes manual for 206 gti
rick-gti
PostPosted: Tue Mar 13, 2012 6:44 am Up
What haynes manual covers the gti's looking for one that covers years from 99-00
clio 197sport owner
davecuk
PostPosted: Tue Mar 13, 2012 7:04 am Up
hi the blue cover doesn't have the GTI engine info for the car, only the mechanicals. the black cover doesn't either, hope this helps,Dave
206 1.9 d silver
PostPosted: Tue Mar 13, 2012 7:10 am Up
davecuk wrote:
but the citroen saxo manual does have 1.6 16 valve engine info.which has been said is the same engine, hope this helps,Dave
Totaly different engine family.
206 GTI is a EW10J4
Saxo 1.6 16 valve is a TU5JP4S.
PostPosted: Tue Mar 13, 2012 7:13 am Up
Probably getting confused with the 206 xsi, even then I personally wouldn't bother they are mostly different.
Nothing for the 2.0 sadly, some dealer software out there that could be useful though.
rick-gti
PostPosted: Tue Mar 13, 2012 7:44 am Up
Just thought one would be handy for when i swop my engines over. Had some trouble with the last one i took out, the o/s driveshaft got damaged as i couldnt get it off while the engine was still in. Cant afford to damage this one as i need it.
clio 197sport owner
gazza82
PostPosted: Tue Mar 13, 2012 8:01 am Up
I'm pretty sure one of the manuals covers the 2.0i engine .. I've got both at home. I'll try and remember to have a look ...
rick-gti
PostPosted: Tue Mar 13, 2012 8:02 am Up
Thanks mate.
clio 197sport owner
Bummers
PostPosted: Tue Mar 13, 2012 10:35 am Up
206 GTI is a EW10J4
do you know if those engines similar enough to make it worthwile getting the saxo VTS haynes to use on the 206 xsi (TU5JP4)?
2003 206xsi 1.6 16valve
gazza82
PostPosted: Wed Mar 14, 2012 7:57 am Up
Black covers the 2.0i 138bhp engine and lots of other GTI related areas. It clearly states it doesn't cover the 180bhp model.
rick-gti
PostPosted: Wed Mar 14, 2012 8:02 am Up
[quote="gazza82"]Black covers the 2.0i 138bhp engine and lots of other GTI related areas. It clearly states it doesn't cover the 180bhp model.[/quote
Is this the one?
www.ebay.co.uk/itm/Hay...2ebc3cdaea
clio 197sport owner
gazza82
PostPosted: Wed Mar 14, 2012 8:08 am Up
Yes, that's mine. Got it for our '02 1.4 HDi and was surprised that it covers most my daughter's Y-reg 206CC!
PostPosted: Wed Mar 14, 2012 8:09 am Up
Yes.
rick-gti
PostPosted: Wed Mar 14, 2012 8:10 am Up
My gti is a 2000 137 not a 138, does that matter?
clio 197sport owner
PostPosted: Wed Mar 14, 2012 1:30 pm Up
They're the same thing.
PostPosted: Wed Mar 14, 2012 1:33 pm Up
I must have been thinking of the xsi that doesn't have a haynes
Very similar just the odd electrical difference
