Latest: DanDan17
Overall: 17128
Online Now [61]:
Visitors: 60
Today: 12779
Total: 100440494
Forums › The Car › 206 Problems › 206 gti problems
206 gti problems
Linkpad
PostPosted: Sun Mar 04, 2012 7:32 am Up
Hi, i got stuff to do Pre MOT :
* Rear brake pads & discs - Can DIY or need special tools ?
* Front Drop Links - DIY or special tools needed ?
* Front lower ball joint arm replacing - What is this part ? Easy to DIY replace ?
Anyone ideas specially the lower arm is that something i can get off ebay ?
Thanks Rolling Eyes
Boo
Martind
PostPosted: Sun Mar 04, 2012 7:37 am Up
Hi
Have you try searching and looking in the how to Guides (They are very helpful)
-Dave-
PostPosted: Sun Mar 04, 2012 7:38 am Up
Trade Rating: +36
Diy job, Look a how to up on youtube if unsure.
Local motor shop will be cheap enough, Might have to grind the old one's off.
Not a clue Laughing
Thanks Rolling Eyes
Ex 206 Owner.
perry081064
PostPosted: Sun Mar 04, 2012 7:39 am Up
Thanks Rolling Eyes
link
this will give you an idea regarding lower ball joint ( wishbone ) and droplinks.
i had mine done at the garage , both wishbones and droplinks fitted and tracking ( will need to be tracked) cost £220.
the job looks easy enough , but it can be a pita to get the old balljoint out, if doing it yourself.
206 2.0 HDI
Linkpad
PostPosted: Sun Mar 04, 2012 7:40 am Up
i see a how to guide for front brakes but aint rear brakes need winding back ? and i dont see any guides to replace drop links or lower arms ive got Haynes but its a bit patchy about rear discs and Drop links ...
Boo
PostPosted: Sun Mar 04, 2012 7:56 am Up
drop link is easy.... just remove 2 nuts to remove the old one and then bolt the new one on...
Linkpad
PostPosted: Sun Mar 04, 2012 8:10 am Up
Yeah thanks ill try that see what spanners i have might need axle stands
Boo
PostPosted: Sun Mar 04, 2012 11:36 am Up
there's no might about it. Unless uour using a 2 or 4 post ramp then allways use axel stands.
Linkpad
PostPosted: Mon Mar 05, 2012 6:58 am Up
So is there anyone here that has changed rear discs & pads or replaced a front arm ? And drop links are a pain to get off so i will have to look when its not raining (sigh)
Boo
PostPosted: Mon Mar 05, 2012 1:13 pm Up
Rear discs and pads are easy. I've got quite a comprehensive piston wind back kit which won't work on the rear calipers. Nothing better than a large screwdriver across the slots in the piston then rotate the piston.
Linkpad
PostPosted: Tue Mar 06, 2012 6:36 am Up
EDWARD I WILL TRY THAT THANKS MATE U A STAR !! I GOT A GOOD G-CLAMP AS WELL ...
Boo
kit325
PostPosted: Tue Mar 06, 2012 7:12 am Up
Brake pads replacement for the front and the back are very easy, drop links replacement are even more simple provided the nuts not seized. Make sure u check the condition of your disc brake (clean it properly/or replce if in bad condition) and get axle stands as it helps a lot and it is safer to work with it.
I suggest u let the garage to change the wishbone as it is a pain in the a**e job unless your very good in diy and there's a change that your driveshaft will pop up and u will have gear oil everywhere. Make sure u get a proper oem quality wishbone as the cheaper one from ebay won't last long consider the amount of labour u need to put it into it.
Goog luck!
kit
PostPosted: Tue Mar 06, 2012 11:59 am Up
No need for a g clamp either! Best not push the pistons back in on an ABS equipped car withouth opening the bleed screw first. Use a proper brake spanner though.
Linkpad
PostPosted: Sat Mar 10, 2012 10:31 am Up
1st attempt at drop links and i got the nuts loose but the thread moves with it, looks like a T25 holds he thread in but tried that and the torx teeth snapped under pressure. I was thinking of molegripping the other side side formt the nut ? There is like plastic backing on the other end can i just bash this off ?
Boo
PostPosted: Sat Mar 10, 2012 12:06 pm Up
I've just cut the nuts off in the past.
