Forums › The Car › 206 Problems › Rear washer hose!!! |
Posted: Sat Mar 10, 2012 10:22 am |
Posted: Sat Mar 10, 2012 10:29 am |
Somebody been doing some welding?
Posted: Sat Mar 10, 2012 10:40 am |
Edward wrote: |
Somebody been doing some welding? |
Wonder if the car has been repaired in the past & if it has was it done correctly
Posted: Sat Mar 10, 2012 10:44 am |
What route does the hose take along the car?
Posted: Sat Mar 10, 2012 10:48 am |
MrBSI wrote: |
Edward wrote: |
Wonder if the car has been repaired in the past & if it has was it done correctly |
Peeled back the rubbers but no sign of any repairs at all.Been under the car quite a lot also and no sign of any accident damage anywhere??
Edward wrote: |
What route does the hose take along the car? |
This was in between the roof lining and the roof?
Posted: Sat Mar 10, 2012 11:05 am |
Drivers wing > A pillar > under headlining on drivers side > drivers C pillar > boot
Posted: Sun Mar 18, 2012 12:16 am |
Im guessing this is not a common problem on the 206 then.
Cant for the life of me think what could of caused this???
