Latest: lio94
Overall: 17181
Online Now [211]:
Visitors: 210
Today: 110866
Total: 141865006
Forums › The Car › 206 Talk › Wishbone bushes
Wishbone bushes
Kelz
PostPosted: Sat Mar 17, 2012 5:05 pm Up
Read a lot about wishbone bushes going in aftermarket wishbones
Can you just change/replace the bushes?
Kelz!
PostPosted: Sat Mar 17, 2012 5:37 pm Up
I think you mean aftermarket bushes in wishbones. there's none really available.
Kelz
PostPosted: Sat Mar 17, 2012 5:40 pm Up
Yeah like can you fit powerflex bushes in the wishbones on gti?
Kelz!
gazza82
PostPosted: Sun Mar 18, 2012 5:01 am Up
The bushes are available, but I'm not sure that they are easy to change without a press. I've got a new arm in the garage and they don't look like they come out easily.
Kelz
PostPosted: Sun Mar 18, 2012 5:28 am Up
Wonder if you could use a vice lol
Need to try find some for it first
Kelz!
kit325
PostPosted: Sun Mar 18, 2012 6:04 am Up
the time and labour u will spend to change the wishbone bushes, u will better off to change the whole arm to ensure u will not need to do this again. Plus if u will need a press to remove the bush, and if your bush is deterioting, just a matter of time before your ball joint causing u problem.
kit
Kelz
PostPosted: Sun Mar 18, 2012 9:08 am Up
Well I have new wishbones coming but I will put powerflex bushes in them before I put them on as I read they are a common problem
Kelz!
PostPosted: Sun Mar 18, 2012 11:07 am Up
Wishbone bushes failing are only a common problem with cheap / aftermarket parts.
Genuine Peugeot parts last years, 6+ & still going strong in my case.
Kelz
PostPosted: Sun Mar 18, 2012 11:23 am Up
I'm not sure which one it is tho, the n/s was replaced 12 months ago
I thought just get some £60 ones(for the pair) and put poly powerflex bushes in them
Would work out about the price of 1 Peugeot one and I would of had both done
Kelz!
PostPosted: Sun Mar 18, 2012 11:29 am Up
Genuine Peugeot wishbone around £120 each, bargain in my eyes Thumbs Up
Fit & forget part.
gazza82
PostPosted: Sun Mar 18, 2012 11:42 am Up
Those bushes are around £25 each ..
Kelz
PostPosted: Sun Mar 18, 2012 12:03 pm Up
So Peugeot ones around 120 each
2 x wishbones £65
2 x front wishbone front bushes £50
2 x front wishbone rear bushes £50
All in at £165 for fully powerflex wishbones
Saving £75
Kelz!
