Latest: DanDan17
Overall: 17128
Online Now [165]:
Visitors: 164
Today: 39018
Total: 100639396
Forums › The Car › 206 Problems › knocking from rear
knocking from rear
ej2_sir
PostPosted: Sun Mar 18, 2012 2:54 pm Up
Evening all,
Right hopefully this will be the last axle related question I need to ask! Evil or Very Mad
I bought an axle off someone on here and fitted it all up. Replaced wheel bearings and discs etc. Everything is fine and dandy.
When taking a sharp left corner at pace I get 2 or 3 knocks from the passenger rear corner. I get no clunks/knocks over rough ground (it did it once over a really bad crater in the road)
So I had a quick look today and there is.....
-No play in axle bearings
-With the car jacked up I cannot recreate the noise with a large plank of wood levering the wheel up and down.
-Shock absorber bushes fine
-Not exhaust/spare wheel etc
So I am quite satisfied that the beam bearings are good before I get the usual "beam knackered" comments.
Anyone shed any light on what to check next?
Im thinking shock absorber (standard items) knocking on out stroke?
ARB needs attention? (beam not lowered but unsure if rebuilt before?)
Axle mounting bushes worn? (felt a little soft when fitted)
Thanks for your thoughts
2002 206 2.0hdi
PostPosted: Sun Mar 18, 2012 3:12 pm Up
Exhaust?
ej2_sir
PostPosted: Sun Mar 18, 2012 3:18 pm Up
Unfortunatly not. That would be nice and easy!
2002 206 2.0hdi
138Andy
PostPosted: Sun Mar 18, 2012 3:58 pm Up
arb drop links worn ?
ej2_sir
PostPosted: Sun Mar 18, 2012 4:19 pm Up
Dont have them on the rear.........
2002 206 2.0hdi
