Latest: DanDan17
Overall: 17128
Online Now [254]:
Visitors: 253
Today: 31620
Total: 100632012
Forums › The Car › 206 Problems › Very high CO levels: MOT Fail
colurwin
PostPosted: Mon Mar 19, 2012 12:48 pm Up
Just my luck... I've not been using my car ('04 206, 1.4i) for 6 weeks due to it not being taxed. I turned it on this morning, and the spanner light came on and the mileometre says "200". I Took it for an MOT and CO reading is very high. (3.2!*) ... Also the normal engine warning light has been on for about 3 months.
My initial thoughts are to check for air leaks, change the filters & plugs, run some decent fuel and redex through it, and check the injector resistance. Also the upstream lambda sensor cable is very frayed (core showing), so going to replace that too.
If that doesn't fix it, my next steps will be to get the error codes read properly, and look at swapping MAP sensor and Coil pack (bougicord fitted currently).
I've got a couple of questions though:
Does the dashboard '200' code diagnose anything, or is it just a general warning? Does it relate to the OBD code p0200?
I have read that the resistance of my injectors should be about 16ohms. Do I have to take the fuel rail off to measure this, or is there an easier way to get at the electrics? And, if I do need to take the fuel rail off, how do i prevent air getting into the system?
And, any other advice greatfully received...
Colin
* Despite my 206 producing more carbon monoxide than a Spanish hotel, they passsed me anyway! Nice One...
PostPosted: Mon Mar 19, 2012 12:53 pm Up
Spanner = car is due a service.
The 200 is just part of the mileage count down to the service.
colurwin
PostPosted: Mon Mar 19, 2012 12:58 pm Up
Cheers mate, I've just discovered the 'how to' section, doing the fix now.
So... Anyone here ever checked their injector resistances?
PostPosted: Mon Mar 19, 2012 2:16 pm Up
What He Said
I dunno why you wanna test your injectors,you have many problems can cause the CO2 to be high,so replace the spark plugs,and the lambada sensor,filters,and you will be ok
colurwin
PostPosted: Mon Mar 19, 2012 2:25 pm Up
I agree there are many reasons why CO could be high... an injector malfunction is one of them... this is why I want to test them, so I can either find the fault or rule them out.
PostPosted: Mon Mar 19, 2012 2:28 pm Up
Top 206 tip so you dont get caught out:
Cylinder number 1 is the GEARBOX end Wink
So many people on here have changed the wrong injector due to them not knowing about PSA's odd back to front cylinder numbering system Laughing
