Latest: Kifi69
Overall: 17183
Online Now [434]:
Visitors: 433
Today: 160566
Total: 144620194
Forums › The Car › 206 Problems › Ph2 Washer Jet Blocked
JDave
PostPosted: Wed Mar 21, 2012 5:41 am Up
Hello again,
Well my passenger side ph2 washer jet seems blocked. I took it off the pipe and steeped it in water and washing up liquid, and while it was off I tested the pipe and the water comes out freely enough; so it seems the problem is within the washer jet itself.
I know with the ph1 you could get a pin and fix it, but what can be the problem with this? The water kinda drips out. Oh and the drivers side works perfect.
Jordan
Click To View My Project
Bassline_Toad
PostPosted: Wed Mar 21, 2012 6:05 am Up
Might be worth getting a new one, only a couple of quid.
PostPosted: Wed Mar 21, 2012 6:08 am Up
Put an air line on the end of the tube leading to the blocked jet & blow it out.
abs06
PostPosted: Wed Mar 21, 2012 6:58 am Up
I had this. I put it in a bowl of boiling water. And the problem was sorted
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
leon206
PostPosted: Wed Mar 21, 2012 10:13 am Up
im selling for £3 to clear my paypal for ph2 washers so let me know , not splitting it though
www.206info.co.uk/Foru...34815.html
peugeot
kit325
PostPosted: Wed Mar 21, 2012 11:06 am Up
If boiling water dun work, use boiling hot water with descale chemical that u normally use for kettle.
It should clear up the limescale that blocked the jet washer.
kit
JDave
PostPosted: Thu Mar 22, 2012 7:17 am Up
When I was at the garage today, the put compressed air through the washer jet and a bit of grit came out. Problem solved!!!
PostPosted: Thu Mar 22, 2012 2:45 pm Up
Who'd have though of that?
JDave
PostPosted: Thu Mar 22, 2012 7:56 pm Up
Aye very good lol! I never had any compressed air and my lungs didn't do the trick.
