Latest: lio94
Overall: 17181
Online Now [199]:
Visitors: 198
Today: 44491
Total: 140989036
Forums › The Car › 206 Problems › Rear suspension squeaking like a b***h
Antknee
PostPosted: Thu Mar 22, 2012 1:22 pm Up
As the subject says... its gone from a clunking to a squeezing, a really loud squeaking, just wondering what it actually is and if its repairable if anyone knows?! It's pretty bad and you can make it squeak just by getting in/out or rocking it ever so slightly
Cant really afford a new axle at the minute so hoping it doesnt come to that lol, also there seems to be a gap on the mounting bush but not sure if its supposed to be like that?
PostPosted: Thu Mar 22, 2012 1:26 pm Up
see if the bolt on the anti roll bar plate has loosen?
there is suppose to have gap between the axle bush
Antknee
PostPosted: Thu Mar 22, 2012 1:28 pm Up
Cheers will go whip the wheel off and check, thanks!
rick-gti
PostPosted: Thu Mar 22, 2012 1:42 pm Up
Any play at 12 and 6 on the wheels? If so the trailing arm bearings need replacing. Best to do them if there's abit of play or its a new beam. I no as mine has gone and squeaks like a bit**
clio 197sport owner
Andy180
PostPosted: Thu Mar 22, 2012 1:48 pm Up
Sounds like the axles screwed, mines just gone as well makes a horrific clunking and squeeking noise on the move as well as a really loud creak when its stationary Sad .
GTI 180
Antknee
PostPosted: Thu Mar 22, 2012 1:55 pm Up
Just had a look at the bolts and one of the b******s just sheared off! Sad
Number 70 on the bottom right..
PostPosted: Thu Mar 22, 2012 1:58 pm Up
so i am right Very Happy
Antknee
PostPosted: Thu Mar 22, 2012 2:01 pm Up
so does this mean i deffo need a new axle? Sad take it it's not safe to drive on that then haha
glenpring
PostPosted: Thu Mar 22, 2012 2:20 pm Up
cant you drill it out and re tap it and new bolt in job done and not much cost
Antknee
PostPosted: Thu Mar 22, 2012 2:22 pm Up
Not sure if its worth it though if the axle needs replacing anyway, dont suppose you know anywhere that sell recon axles at a good price?
Andy180
PostPosted: Thu Mar 22, 2012 2:28 pm Up
IMaxles have got a decent reputation
GTI 180
ej2_sir
PostPosted: Thu Mar 22, 2012 2:40 pm Up
I wouldnt bother with an axle just because the end plate bolt has sheared? Why is everyone on this forum obssessed with buying recon axles? If you cant drill and easyout the bolt just take it to a garage/engineering shop. probably cost about £30. Or get a recon axle for £400.............
2002 206 2.0hdi
Antknee
PostPosted: Thu Mar 22, 2012 2:47 pm Up
The bolt isnt the only reason i was asking about reconditioned axles, i can take the bolt out myself
PostPosted: Thu Mar 22, 2012 3:30 pm Up
a set of bearing is at least 4 times cheaper than re-con axle
Martind
PostPosted: Thu Mar 22, 2012 5:52 pm Up
Hopefully it is nothing too major, but I also have a little sqeek from the rear.
Only when getting in and out of the car, and when you put the handbrake on when on a hill. Sometimes when the back of the car comes off a speedbump.
No other noises/clucks etc come from the rear at all, so I have just put it down to the shocks being a bit dry.
After a little search, I have found that it may possibly be the spare wheel rubbing which I will check tomorrow, also I will be giving the wheels a good wobble.
I hope it isn't anything serious. It would be a little odd seeing as someone spent a lot of money on the shocks (a lot of money on everything really, and not all that long ago by the looks of them) and to not check everything out whilst underneith.
Wish me luck!
