Online Now [521]:
Visitors: 520
Today: 114694
Total: 156467088
Forums › The Car › 206 Problems › Not the usual remote locking problem.
Rob2859
PostPosted: Tue Mar 27, 2012 7:24 am Up
I am really looking to get this sorted now. I had quite a productive day already. Even Lee is not sure on this one. (Thanks again for the BSI config and your help so far).
The problem is this; the car will not unlock via remote when the BSI powers down. It does however lock and unlock when the BSI is awake.
If I remember correctly the problem started when I changed the BSI although Lee doesn't think it has anything to do with the configuration. The remote being used is the one that came with that BSI.
broadblaster
PostPosted: Tue Mar 27, 2012 12:42 pm Up
i'v got the same sort of problem, mine will not unlock on the fob but will lock fine but i have not changed anything it just stopped working.
do all your doors and boot unlock via the key ????? mine will only unlock the door the key is in but not the others.
on a back road playing
Rob2859
PostPosted: Tue Mar 27, 2012 1:08 pm Up
Yes they do. You probably have a dead solenoid.
broadblaster
PostPosted: Tue Mar 27, 2012 1:40 pm Up
i would have thought if it was a solenoid the other locks would have worked tho ???
starting to get a bit annoying as not got in the boot for mths lol (unless i climb into the back and do it by hand)
