Online Now [82]:
Visitors: 81
Today: 46055
Total: 140039506
Forums › The Car › Request a how-to › How to remove airbox cover
Forum IndexRequest a how-to
PostPosted: Tue Mar 27, 2012 11:23 am Reply with quote Up
Does anyone know how to remove the top cover of the airbox which looks like this
PostPosted: Tue Mar 27, 2012 11:45 am Reply with quote Up
There is a hole at the side where a screwdriver can be inserted to undo the jubilee clip that hold the cover onto the throttle body. A torch might help you see the screwhead of the clip.
Martind
PostPosted: Tue Mar 27, 2012 12:01 pm Reply with quote Up
Just inside there mate
PostPosted: Tue Mar 27, 2012 12:06 pm Reply with quote Up
cheers guys, hopefully removing it will give me room to remove the icv
PostPosted: Tue Mar 27, 2012 1:20 pm Reply with quote Up
Well it should do because then it will look like this.
PostPosted: Tue Mar 27, 2012 1:23 pm Reply with quote Up
thanks mate, will give it another go on thursday
PostPosted: Thu Mar 29, 2012 2:53 pm Reply with quote Up
Dont you miss your plastic manifold Edward?!
00budham00
PostPosted: Thu Mar 29, 2012 3:42 pm Reply with quote Up
dont split the rubber bit £45 for replacement from pug
PostPosted: Fri Mar 30, 2012 7:44 am Reply with quote Up
It's still in the cupboard at home so I take a look now and again.
  Quick Reply
Username:
Message:
Quote the last message
