Online Now [103]:
Visitors: 102
Today: 65412
Total: 117019360
Forums › The Car › 206 Problems › LED rear lights reverse problem
Markzedd
PostPosted: Wed Mar 28, 2012 2:14 pm Up
Hi, I've just bought a 206 with the LED rear lights. They both work fine except I don't get a reverse light... Is there anything I can do to fix them..
Thanks in advance
Mark
PostPosted: Wed Mar 28, 2012 2:17 pm Up
So you have no reversing lights at all? Are you sure that there is bulbs in there?
Markzedd
PostPosted: Wed Mar 28, 2012 2:21 pm Up
It's the LED ones so I thought they should be in, and it's on both sides.
Hi,,,,,
PostPosted: Wed Mar 28, 2012 2:24 pm Up
LED rear lights dont normally have LED reversing lights, they are normally just standard bulbs.
What lights have you got? A picture will help....
Markzedd
PostPosted: Wed Mar 28, 2012 2:41 pm Up
don't if this will work but it's those lights
Markzedd
PostPosted: Wed Mar 28, 2012 2:42 pm Up
tamz
PostPosted: Wed Mar 28, 2012 2:48 pm Up
i have the same 1s and its defo standard builbs in them Smile
Markzedd
PostPosted: Wed Mar 28, 2012 2:51 pm Up
Thanks for that, is it easy to get at the bulbs. This car is new to me and have just noticed there's no reverse lights on..
PostPosted: Wed Mar 28, 2012 2:54 pm Up
Yeah standard bulbs.
To get to them you nee to unscrew the nut behind the boot carpet.
DeadEyePaul
PostPosted: Wed Mar 28, 2012 3:05 pm Up
Same lights as yours but different colour
Has a white bulb in for reverse can easily be bought from any car shop
If new bulb doesn't solve it is possible the plug in the passenger footwell has been disturbed
Markzedd
PostPosted: Wed Mar 28, 2012 3:11 pm Up
Thanks for that where abouts is the plug in the footwell?
Hi,,,,,
DeadEyePaul
PostPosted: Wed Mar 28, 2012 3:18 pm Up
Its underneath the glovebox, it can accidentally be kicked by passengers
Markzedd
PostPosted: Wed Mar 28, 2012 3:30 pm Up
I'll have a look. Thanks...
Hi,,,,,
PostPosted: Wed Mar 28, 2012 3:44 pm Up
That's for the brakes not the reverse lights Laughing
Markzedd
PostPosted: Thu Mar 29, 2012 1:13 am Up
I've just something about the speed sensor being on the same fuse, and when I've just looked round the car it looks like there's been a electrical connector taken off and it's near where the speed sensor is ( the passanger arch) so I think the last person must have had a fault and either blown the fuse and taken the speed sensor off because the reverse lights and speed sensor are on the same fuse. Does anyone know where the speed sensor is and what it look like, because iam sure it will have something to do with that ( there's a bit of burn mark on one of the pins in the connector) thanks
