Posted: Fri Mar 30, 2012 12:35 pm |
Fitted my new (second hand) icv last night but its still idling below 750, i'd say at 600 revs. Is this normal and if it's not what can i do to get the revs to where they should be?
Posted: Fri Mar 30, 2012 12:38 pm |
Is it idling smooth?
Posted: Fri Mar 30, 2012 12:40 pm |
It is a little when the engine first fires up but then when the revs drop it does sound like its struggling a little but everything is fine
Posted: Fri Mar 30, 2012 12:44 pm |
Mine does exactly the same.
Steady idle at 600ish revs. Cleaned out everything and still no change. No Warning Lights and never stalls.
On A/C it idles closer to 900 but on ECO it always stays at 600ish
Posted: Fri Mar 30, 2012 12:47 pm |
Thats exactly like mine does so it must be normal on older gti's as mine is the same year as yours Martin
Posted: Fri Mar 30, 2012 12:53 pm |
MattyP wrote: |
Thats exactly like mine does so it must be normal on older gti's as mine is the same year as yours Martin |
Thats good to hear then, Sounds like nothing to worrie about
Posted: Fri Mar 30, 2012 1:15 pm |
il start mine up 2moz n let u both no mines a 2000
