Online Now [884]:
Visitors: 883
Today: 201568
Total: 152594509
Forums › The Car › 206 Problems › No fan when ac is on?
Kelz
PostPosted: Sun Apr 01, 2012 10:33 am Up
Been told the fan should come on when I switch air con on?
But I switch it on and it makes no difference the fan doesn't come on BUT when temp goes up to 92 the fan does come on and cools it down
Anyone know what the probably may be with this?
Kelz!
PostPosted: Sun Apr 01, 2012 10:38 am Up
Your aircon system is low on gas.
Kelz
PostPosted: Sun Apr 01, 2012 10:41 am Up
Ahh I did think it was low anyway as doesn't seem to get very cold, does this affect the fan too then? I thought it would just come on still even it's low on gas lol
Kelz!
PostPosted: Sun Apr 01, 2012 10:42 am Up
Pressure safety switch stops the aircon compressor cutting in which it turn means there is no need for the cooling fan to run.
Kelz
PostPosted: Sun Apr 01, 2012 10:44 am Up
So when air con says it is on its actually not making any difference?
How much would I be looking at to have the gas topped up?
Kelz!
PostPosted: Mon Apr 02, 2012 9:34 am Up
Kwikfit used to charge £50 with no fix no fee. If your aircon hasn't been used for a while the seals may be knackered so it won't hold a charge. If that is the case you effectively get it tested for free.
weegingerzulu2011
PostPosted: Thu Apr 05, 2012 4:42 pm Up
Change both green relays and resistore in fan house bobs ya teapot
ginge Smile
PostPosted: Fri Apr 06, 2012 1:42 am Up
That won't help because the fan works when the engine gets hot - Therefore the relays obviously work.
PostPosted: Sat Apr 07, 2012 3:43 pm Up
+1 what Edward said.
+1 what MrBSI said.
