Latest: tbafonso
Overall: 17130
Online Now [138]:
Visitors: 137
Today: 4327
Total: 103866514
Forums › The Car › 206 Talk › 206 disk conversion
206 disk conversion
BigGreenDave
PostPosted: Mon Sep 17, 2012 12:47 pm Up
So I ended up buying a 206 GTI/HDI rear disk axle my car was originally a 1.4 but I had a GTi Engine swap so I might as well get it finished and go for the discs, all I'm needing now is the handbrake cable and calipers, to say I bought this axle off eBay without and image it's in great condition just bonze from rust flake, WISH ME LUCK as I never knew just how heavy the rear axles on 206's were.
F**k Scene YAWN
anton1989
PostPosted: Mon Sep 17, 2012 1:02 pm Up
Trade Rating: +16
your mad mate, buying a rear axle with out any pics or worst no even going to see it!!!
your need more than good luck lol
how much it set you back?
BigGreenDave
PostPosted: Mon Sep 17, 2012 2:10 pm Up
Lol I have the rear axle I wasn't paying for it without seeing it but £60 is a bargain :.P nothing wrong with it just a bearing that needs changing but I plan on renewing all bearings and changing shockers ect the torsion bars are better condition then mine and the disks are almost brand new. So good find :.D
F**k Scene YAWN
PostPosted: Mon Sep 17, 2012 3:09 pm Up
Just a bearing needs changing...good luck.
