Latest: tbafonso
Overall: 17130
Online Now [295]:
Visitors: 295
Today: 26125
Total: 104557932
Forums › The Car › 206 Problems › What is wrong with my blummin car?
Go to page Previous  1, 2
frankaai
PostPosted: Sat Apr 07, 2012 4:52 am Up
frankaai wrote:
Do you have an upgraded alarm? this could take alot of power from the battery
My friend in the office drives an impreza with an upgraded alarm, he had to turn his imobilizer off because he would only use the car at weekends etc, but the battery would be dead if not drove from time to time, he just kept his alarm off, done the trick
devildriverxii
PostPosted: Sat Apr 07, 2012 11:40 am Up
Seb wrote:
How long does it take to go flat?
And how old is the battery? On the VX, despite it hardly having anything that could even drain the battery, it would go flat overnight. Replaced it and now it lasts several weeks before it needs a jump/bump start.
Sounds like mine.
The old one was about 2 years old, but it got changed 4 days ago, andf it went flat the first night.
2002 1.6 5dr Black Edition.
davecuk
PostPosted: Sat Apr 07, 2012 11:55 am Up
hi, have the earths been checked for bad/ loose connections? had an escort several years ago, a bad body earth drained battery, and at one point, didn't have any interior power, but the engine was running ok.worth a look. Dave
206 1.9 d silver
DeadEyePaul
PostPosted: Sat Apr 07, 2012 11:57 am Up
I had the same battery issues as you stated above but I changed my battery for a bosche s4 and since then I can leave my car for days and it still starts
devildriverxii
PostPosted: Sun Apr 08, 2012 2:48 am Up
Really?
Funny, my car did originally have a bosche branded battery in it when I first got it.
I a few people have said certain brands of battery are recommended for 206's.
Thanks for all your help, I'll try getting another battery, I should get my money back for this one right?
PostPosted: Sun Apr 08, 2012 3:14 am Up
Varta or Bosch everytimg for car batteries.
Bosch batteries are just Varta's with different stickers on Wink
millerman
PostPosted: Tue Apr 10, 2012 11:01 pm Up
devildriverxii wrote:
Something is draining my car battery.....
Any joy fixing this yet, my Wifes car has just stated doing the same, charge it up, drive it, leave overnight and its dead next morning.
If you think no one cares, try missing a mortgage payment!
millerman
PostPosted: Sat Apr 14, 2012 10:05 am Up
Problem solved for me, under the ecu there is what i deem to be a relay/control box, this had its fixing lug broke which had left a hole in the casing allowing moisture to enter, infact a few drops of brown water fell out along with some rust!! Out test meter was reading silly numbers like 7.5, when we disconnected this box the numbers fell to a steady 0.36. This black relay/control box has 15 pins and has the number 240107 and the name BITRON or thats what my tired old eyes seem to see. Any one know the name of this bit of equipment and is the number the part number? I'm assuming it controls the fuel pump 'cause it was running all the time, i would also assume it is ignition related.
PostPosted: Sat Apr 14, 2012 10:07 am Up
Whats the VIN number, Ill have a look on Service Box.
millerman
PostPosted: Sat Apr 14, 2012 10:49 am Up
You Sir are a legend. Cool VIN is; VF32CKFXP40859775
1.4 LX 8v Auto
PostPosted: Sat Apr 14, 2012 11:08 am Up
Double 20 / 30 amp relay under the ecu is Peugeot / Citroen part number 4549 35 Relay £44.27
Check the part number is correct with a main dealer before ordering it!
millerman
PostPosted: Sat Apr 14, 2012 11:28 am Up
Many thanks. Cool
Page 2 of 2
