Posted: Fri Apr 06, 2012 10:41 am |
i have put a after market 8 ball gear knob on my car awhile ago but still think it sits to high. if i trim pole down it sits on will i have any troubles?
Posted: Fri Apr 06, 2012 10:42 am |
Couldn't you just drill the hole deeper in to the ball? As if you chop the pole down you might have a problem when you come to put a standard one back on if you change your mind in the future
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Posted: Fri Apr 06, 2012 10:43 am |
shouldnt do but maybe better to drill the gear knob? and tap the hole a bit deeper.... so if you ever want to get rid of that knob and change it.. you can without issues
Posted: Fri Apr 06, 2012 11:01 am |
cant drill it any further that why was goin cut lower. i don't have stanrad one anymore
Posted: Fri Apr 06, 2012 11:03 am |
you wont have any trouble if you cut your stick customise your car to fit your needs as you will be the one driving it
Posted: Fri Apr 06, 2012 11:12 am |
20619d wrote: |
if i trim pole down it sits on |
That 'pole' is the gear lever or stick.
Posted: Fri Apr 06, 2012 11:32 am |
Have a look around at other members car pictures who have 8 ball gear knobs and ask them where they got there's from if they fit better than yours, for the sake of £5-10 it will save you hacking things to bits and future trouble putting other ones on
