Latest: DanDan17
Overall: 17128
Online Now [64]:
Visitors: 63
Today: 14651
Total: 100534589
Forums › The Car › 206 Talk › Strange wire? Any ideas?
Sk3rry93
PostPosted: Sun Apr 08, 2012 9:49 am Up
So can anybody shed some light on what this is? its not creating any problems but im just looking to know for reference really
heyziq
PostPosted: Sun Apr 08, 2012 9:57 am Up
alarm?
heyziq.com
138Andy
not sure but mine goes into the wing not sure what its plugged into maybe your side repeater ?
PostPosted: Sun Apr 08, 2012 10:04 am Up
heyziq wrote:
alarm?
Correct Wink
Sk3rry93
PostPosted: Sun Apr 08, 2012 10:45 am Up
So alarm then guys? So presumably having this disconnected would result in my alarm not working?
davecuk
PostPosted: Sun Apr 08, 2012 11:07 am Up
hi, depends if the alarm was fitted as standard, loom may be fitted, but not all accessories are fitted.they tuck away the unused loom plugs.if you go on to peugeot service box you can find out the specs of fitted accessories via the VIN hope this helps, Dave
206 1.9 d silver
PostPosted: Sun Apr 08, 2012 11:13 am Up
Peugeot's normally have most / all the extra connector plugs on for higher spec models as its cheaper adding a few connector plugs to every loom then making lots of different spec looms.
If the rest of the wiring loom / plugs are there & the BSI unit is capable then you could always retrofit the alarm system.
You would need:
Boot sensor
Bonnet sensor
Ultrasonic sensors + covers
Ultrasonic button
Hazard / lock button
Alarm siren
Alarm control unit
All these parts are cheap 2nd hand from breakers / Ebay etc
The you need someone with Peugeot Planet to set it up.
Sk3rry93
PostPosted: Sun Apr 08, 2012 11:49 am Up
You would need:
Boot sensor
Bonnet sensor
Ultrasonic button
Alarm siren
Alarm control unit
Is the hazzard/lock button the centeral locking button inside the car? if it is then i have that as standard
PostPosted: Sun Apr 08, 2012 11:54 am Up
One less part to retrofit then Laughing
Sk3rry93
PostPosted: Sun Apr 08, 2012 11:57 am Up
Whooooooo i now have something else to add to the list of things to be done
PostPosted: Sun Apr 08, 2012 11:59 am Up
Should be a blue multiplug next to handbrake lever for ultrasonic switch.
Brown plug near boot latch for that sensor & a black plug behind grill next to drivers headlight for the bonnet sensor.
Sk3rry93
PostPosted: Sun Apr 08, 2012 12:18 pm Up
Okay ill go have a look see what I can find ....... Okay so no blue multiplug near handbrake no brown plug near boot. But i did find a brown plug behind the grill
morcibacsi
PostPosted: Mon Apr 09, 2012 1:44 pm Up
When investigating the engine-bay I found this behind the battery. What could be this? (sorry its a bit blurry Sad )
PostPosted: Mon Apr 09, 2012 2:18 pm Up
Alarm control unit is the BSI
PostPosted: Mon Apr 09, 2012 3:29 pm Up
there's an extra black box for the alarm on multiplexed with blue plug one end & brown plug for ultrasonic on the other, clips up next to BSI unit.
