Latest: heikkisj
Overall: 17126
Online Now [47]:
Visitors: 46
Today: 16639
Total: 100214247
Forums › The Car › 206 Problems › driveshaft seal?
driveshaft seal?
paulspug
PostPosted: Sat Apr 28, 2012 12:59 pm Up
hi
off to have a go at fitting a clutch in my 2002 gti, i have have the clutch and oil but have been told i will need to replace a driveshaft seal?
now, is this true (i have no idea atm), and if so can anyone tell me what the part number is /or is there a specific seal to purchase over oem (upgrade).
i have many years building motorcycles, so am not a total noob at things,and just need some clarity atm
thanks all Smile
ab16
PostPosted: Sat Apr 28, 2012 1:02 pm Up
a cv boot is probably what your looking for. there is an inner and outer cv boot. Your probably looking for the inner 1
wanted-
ph2 bootstrip
16'' nimrods
sports front and rear bumpers
ph2 rear lights
PM with any good deals Wink
broadblaster
PostPosted: Sat Apr 28, 2012 1:12 pm Up
there is a drive shaft oil seals i did change mine when i done my clutch and the input shaft seal iirc think they came in around 30 for all 3 from dealers. tbh the drive shaft ones were fine but as i had them i did change them but the input shaft one was very worn.
on a back road playing
paulspug
PostPosted: Sat Apr 28, 2012 1:37 pm Up
thanks
broadblaster
PostPosted: Sat Apr 28, 2012 1:41 pm Up
does depend on what model car yours is as to the input shaft seal tho think its only on the 1.6 engine and upwards
broadblaster
PostPosted: Sat Apr 28, 2012 1:52 pm Up
this is the input seal mate www.ebay.co.uk/itm/206...0683932677
hayes_ctfc
PostPosted: Sat Apr 28, 2012 2:05 pm Up
The most common Driveshaft seal part numbers are 312144 and 312146 (off side and near side) and the input seal (Top hat seal) is most commonly 210535 as a guide if you go into a dealership to ask for part numbers.
OLD: Peugeot 206 2.0 GTi 138
NEW: Seat Leon FR TDi 170
paulspug
PostPosted: Sun Apr 29, 2012 4:03 am Up
thanks for the part numbers and all for advice Smile
