Latest: tbafonso
Overall: 17130
Online Now [68]:
Visitors: 67
Today: 26257
Total: 104438439
Forums › The Car › 206 Problems › Engine mount question
karimali831
PostPosted: Fri Apr 13, 2012 2:25 pm Up
When there is a sudden release to the acceleration, more so to the first and second gear there is a sudden jump to the engine? Can make it sometimes awkard to drive so now I want to get it fixed up. Could it be the engine mounts need replacing?
Thanks Smile
206 GTI 180
PostPosted: Fri Apr 13, 2012 4:37 pm Up
Thanks Smile
Could be that, or could be that your driving style needs improving.
martinius88
PostPosted: Fri Apr 13, 2012 4:40 pm Up
i had something similar, and it was the rear lower engine mount, got that replaced with a vibra technics one and its all sorted now. Product code for that is PUG301B. Hope that helps
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
PostPosted: Sat Apr 14, 2012 1:25 am Up
Don't lift off the throttle so suddenly.
karimali831
PostPosted: Sat Apr 14, 2012 4:44 am Up
Thanks all, it does jump no matter how steady I release but more sudden the release, worse the jump.
206 GTI 180
