Latest: DanDan17
Overall: 17128
Online Now [351]:
Visitors: 350
Today: 22849
Total: 100692255
Forums › The Car › 206 Problems › gear linkage issue
gear linkage issue
Walton450
PostPosted: Thu Apr 12, 2012 1:20 pm Up
Having a issue with going from 2nd to 3rd and 4th to 5th and the same back down. The gear lever goes very stiff the car has had new linkages and the clutch changed about 6 months ago,if anyone else has has this and knows a fix please help.
I\'m Steve got a 2003 verve.
novatron1_2
PostPosted: Wed Apr 18, 2012 12:34 pm Up
If it feels better with the engine off I'd say the clutch wasn't disengaging properly.
If it feels the same, try reaching down the back of the engine and hitting the linkages with some spray grease and working it in. This will work better if you can do it from underneath and this'll let you do the bottom of the gear lever as well.
Does it jump out of gear at all? Have you checked the gearbox oil level?
206 1.9D, 210,000 now dead following failed submarine experiment (flood)
cbgl
PostPosted: Wed Apr 18, 2012 12:44 pm Up
On the 206 GTI there is a round large ball that revolves in a tube, this turns as gears are selected, have noticed huge improvement when this ball is lubricated, I tried a heavy grade grease, works fine, cannot understand why ends of the tube holding ball are not covered or sealed off from dust, maybe my car is missing something, best regards to all.
Have 206 GTI & 306 XT N5
novatron1_2
PostPosted: Wed Apr 18, 2012 1:46 pm Up
It's is strange how open the elements it all is, when I changed my clutch I took the whole linkage apart and greased it all with some water resistant grease made by Shell, I bought at an auto-jumble. It's a bit of a pain to get to normally with it being stuck behind the engine. You can see why they went to cable with the 207.
