Online Now [189]:
Visitors: 188
Today: 51718
Total: 142320194
Forums › The Car › 206 Problems › Under Bonnet silencer
danlouiee
PostPosted: Sat Apr 14, 2012 4:16 am Up
Could someone please take a picture of their under bonnet silence and show me how it is fitted?
PostPosted: Sat Apr 14, 2012 4:36 am Up
I think you mean the catalytic converter.
Four nuts hold it on threaded studs with a seal in-between.
It is normal to look leaning like the tower of piza.
oldskoolz
PostPosted: Sat Apr 14, 2012 4:58 am Up
i think he actually means the mat that goes under the bonnet to reduce engine noise
Black 206 Gti. Soon to be 2.2
PostPosted: Sat Apr 14, 2012 5:03 am Up
Ah.
danlouiee
PostPosted: Sat Apr 14, 2012 5:08 am Up
Yeah the silencer mat that goes under the bonnet! Thanks anyway!
PostPosted: Sat Apr 14, 2012 5:16 am Up
it secures the same way the bonnet vent is mate, with those black clips which the centres pull out slightly
davecuk
PostPosted: Sat Apr 14, 2012 5:19 am Up
hi, it fits in the deeper space of the bonnet and is fixed with the plastic mushroom rivets (as used on the inner wings etc). you will see the holes to fix it around the framework of the bonnet. Dave
206 1.9 d silver
danlouiee
PostPosted: Sat Apr 14, 2012 7:39 am Up
I've out the 9 clips in I bought them from Peugeot and they are slightly different..only problem I'm having though is it sags in middle and won't sit up properly and the only way it will stay up is if I cable tie it and one broke today because it was so brittle!
davecuk
PostPosted: Sat Apr 14, 2012 8:39 am Up
hi, just a thought, if you have some spray glue, use that to hold the felt up. Dave
206 1.9 d silver
danlouiee
PostPosted: Wed Apr 18, 2012 1:09 am Up
I would but the heat from the engine would just heat the bond back up surely? I think I need to see one o be honest!
