Latest: sparrowdclxvi
Overall: 17139
Online Now [77]:
Visitors: 76
Today: 5843
Total: 113281379
Forums › The Car › 206 Problems › 1st gear noise
1st gear noise
206racer
PostPosted: Sun Apr 15, 2012 8:55 am Up
Went out this morning started up and while putting in to 1st gear could feel a slight viberation as if the cogs where not lined up,did this until the car had warmed up and now doesnt do it.Could it be the slave cylinder or the clutch.It doesnt lose power uphills and revs dont go up.How do i check if its a cable or hydraulic clutch?thanks
51 reg 2002 1.1 petrol
hello
PostPosted: Sun Apr 15, 2012 8:59 am Up
It will be a cable on your TU1 with MA box.
206racer
PostPosted: Sun Apr 15, 2012 9:01 am Up
thanks but whats a MA box
MANUAL gearbox?
hello
The type of gearbox fitted to your 206.
206racer
PostPosted: Sun Apr 15, 2012 9:02 am Up
do you know if the cable can be adjusted or do i buy a new one?
hello
PostPosted: Sun Apr 15, 2012 9:04 am Up
The cable is self adjusting.
206racer
PostPosted: Sun Apr 15, 2012 9:06 am Up
ok thanks i will buy a new1 see if thats my problem.
hello
PostPosted: Tue Apr 17, 2012 6:52 am Up
Change the gearbox oil anyway.
Make sure you put in OEM (Total 75W80 non-synthetic) only, as it makes a huge difference.
I don't know how the cable would cause this tbh.
