Latest: TigerHunters
Overall: 17144
Online Now [54]:
Visitors: 53
Today: 10726
Total: 115883986
Forums › The Car › 206 Problems › Engine Cutting Out First Thing In The Morning
willym85
PostPosted: Mon Apr 16, 2012 5:48 am Up
Hi All,
First post in the forums. My Sister's car is playing up. It started every now and again but quite regular now. Car starts up fine in the morning but when you pull away it stalls. Only seems to happen in the mornin and there is no faults being registered.
took it to the Garage they say they tested the battery and its fine and no faults. Annoying though as it never happens when its with them.
Anyone have the same problem or can recommend a fix?
Cheers
Will
206 1.4
Ash
PostPosted: Mon Apr 16, 2012 9:07 am Up
Clean the Stepper Motor/Idle Control Valve.
You'll find a How To somewhere if you search.
PostPosted: Mon Apr 16, 2012 9:09 am Up
I had exact problem and Mine turns out to be map sensor.
Ash
PostPosted: Mon Apr 16, 2012 9:12 am Up
P.S. Is it a Petrol?
willym85
PostPosted: Tue Apr 17, 2012 7:56 am Up
yep its petrol 1.4 . I will try cleaning that then. Is there anyway to diagnose whether its a map sensor before i but the part?
206 1.4
