Latest: Mr-Koekwaus
Overall: 17125
Online Now [74]:
Visitors: 73
Today: 45565
Total: 100128293
Forums › The Car › Solved 206 Problems › Battery going flat over night. [SOLVED]
millerman
PostPosted: Sun Apr 15, 2012 10:58 pm Up
Battery kept dying over night, bought new battery, still does it, got a chap in with his muli-meter and he traced the voltage drain to a large relay that sits under the ECU, i believe it controls the fuel pump. The relay is bolted on but the retaining plastic lug had broke of some time in the past and moisture had been entering the relay, a few droplets of brown water actually fell out ot it, once it was removed the voltage drain disappeared. Got to order a new one from Peugeot today, the Mrs is a happy bunny once more.
BTW, dont know what those little nuts are called that secure the ecu, but they are a bugger to remove!
If you think no one cares, try missing a mortgage payment!
Ash
PostPosted: Mon Apr 16, 2012 12:23 am Up
You're welcome Smile
