Latest: Makomeister18274
Overall: 17122
Online Now [65]:
Visitors: 64
Today: 6895
Total: 97817471
Forums › The Car › 206 Talk › What water temperature does you 180 hang around?
Stigter
PostPosted: Thu Apr 19, 2012 1:40 pm Up
Just wanted to know what water temp people with 206 gti 180 hang around on normal driving?
Many thanks in advance
Can\'t be blank
PostPosted: Thu Apr 19, 2012 1:41 pm Up
it will have to be between 90 and 100
Stigter
PostPosted: Thu Apr 19, 2012 1:47 pm Up
Mine only shows about 80, anyone had issues with sensor, guessing its the green one that needs changing?
Any help would be welcomed
Can\'t be blank
PostPosted: Thu Apr 19, 2012 1:50 pm Up
Too much anti freeze, ever thought about that?
Stigter
PostPosted: Thu Apr 19, 2012 2:30 pm Up
Might just change the sensor and see how it goes.
Can\'t be blank
PostPosted: Thu Apr 19, 2012 2:34 pm Up
could be the thermostat stuck open too
Stigter
PostPosted: Thu Apr 19, 2012 2:42 pm Up
You know what - think I just need to drive the thing and stop needing to check and fix everything.
Can\'t be blank
jayz206gti
PostPosted: Thu Apr 19, 2012 2:54 pm Up
Mine stays at 90 and creeps up in traffic
Upgraded from 138 to 180
L5_UKS
PostPosted: Thu Apr 19, 2012 3:47 pm Up
Yep should be around 90. mine sometimes goes slightly over but thats normal.
Icetto
PostPosted: Fri Apr 20, 2012 1:03 am Up
mine is just under 90 when the car has been driving for a few minutes
MrrNoName
PostPosted: Fri Apr 20, 2012 1:06 am Up
Thumb Up
Stigter
PostPosted: Fri Apr 20, 2012 1:13 am Up
Doh, its not going to fix its self I guess. Will change the sensor and see what happens and report back. Many thanks for replies.
Can\'t be blank
JamieM
PostPosted: Fri Apr 20, 2012 1:16 am Up
As said, 90 and creeps up in traffic only a little though!
Aegean Blue 206 GTi180
Johnbyron
PostPosted: Fri Apr 20, 2012 2:28 am Up
mines always slightly under 90, only ever seen above 90 when it has been stood ticking over for too long in the drive
Ash
PostPosted: Fri Apr 20, 2012 5:43 am Up
Doesn't every car sorta aim to be at 90?
