Posted: Thu Apr 19, 2012 1:40 pm |
Just wanted to know what water temp people with 206 gti 180 hang around on normal driving?
Many thanks in advance
Posted: Thu Apr 19, 2012 1:41 pm |
it will have to be between 90 and 100
Posted: Thu Apr 19, 2012 1:47 pm |
Mine only shows about 80, anyone had issues with sensor, guessing its the green one that needs changing?
Any help would be welcomed
Posted: Thu Apr 19, 2012 1:50 pm |
Too much anti freeze, ever thought about that?
| Team Impossible Possible
Posted: Thu Apr 19, 2012 2:30 pm |
| Addaz wrote: |
| Too much anti freeze, ever thought about that? |
Might just change the sensor and see how it goes.
Posted: Thu Apr 19, 2012 2:34 pm |
could be the thermostat stuck open too
Posted: Thu Apr 19, 2012 2:42 pm |
You know what - think I just need to drive the thing and stop needing to check and fix everything.
Posted: Thu Apr 19, 2012 2:54 pm |
Mine stays at 90 and creeps up in traffic
Posted: Thu Apr 19, 2012 3:47 pm |
Yep should be around 90. mine sometimes goes slightly over but thats normal.
Posted: Fri Apr 20, 2012 1:03 am |
mine is just under 90 when the car has been driving for a few minutes
Posted: Fri Apr 20, 2012 1:06 am |
| Stigter wrote: |
| You know what - think I just need to drive the thing and stop needing to check and fix everything. |
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Fri Apr 20, 2012 1:13 am |
Doh, its not going to fix its self I guess. Will change the sensor and see what happens and report back. Many thanks for replies.
Posted: Fri Apr 20, 2012 1:16 am |
As said, 90 and creeps up in traffic only a little though!
Posted: Fri Apr 20, 2012 2:28 am |
mines always slightly under 90, only ever seen above 90 when it has been stood ticking over for too long in the drive
Posted: Fri Apr 20, 2012 5:43 am |
Doesn't every car sorta aim to be at 90?
