Online Now [647]:
Visitors: 646
Today: 137262
Total: 149536084
Forums › The Car › 206 Talk › Door Cards
Door Cards
Forum Index › 206 Talk
deebee
PostPosted: Mon Apr 16, 2012 3:17 pm Up
Hi guys!
Basically I've got a 3 door gti set and swapping it into a hdi but thing is I've done rear and glove box, but when it comes to door cards, the top seems shorter and the lock pin overlaps the top making it unlock able.
HELP!!!!
Scott
Breaking 2.0 hdi with ps and gti bits
PostPosted: Mon Apr 16, 2012 3:25 pm Up
There are two styles. Phase one and two.
There is also a rare one that's on the newest 206's that don't have locking pins
deebee
PostPosted: Mon Apr 16, 2012 3:36 pm Up
so what can i do to make them fit?
PostPosted: Mon Apr 16, 2012 3:52 pm Up
Even so earlier ones will still fit the door fine, do you have any pictures? I don't think you are fitting them correctly in the window seal to be honest.
deebee
PostPosted: Sat Apr 21, 2012 5:00 am Up
I am mate, I've tried about 10 times on different days and I've had past exp fitting them as i fitted the same ones to my 206 van 2 years ago, basically you know the side of the door there no screw hole either and few of the white clip ons are in different places swell as the door lock is raised above it and the top of the door card seems straighter than the one on which seems bent.
