Posted: Mon Apr 23, 2012 5:40 am |
Posted: Mon Apr 23, 2012 5:52 am |
I think thats just a part of the original cold air feed, could be wrong tho
| Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html | |
Posted: Mon Apr 23, 2012 6:09 am |
That's what I thought looks like cold air feed pipe.
| Everyone should drive hybrids, that way there's more petrol for me! | |
Posted: Mon Apr 23, 2012 6:11 am |
Just realised that the pictures don't really show scale - it's not really that big.
Here's another angle with a 2p coin in view:
The round end (facing) in the above picture has lugs that suggest it twists into something to lock into place - dunno what though...
Posted: Mon Apr 23, 2012 6:16 am |
Have you looked under the car and seen if it looks like there's anything missing?
Posted: Mon Apr 23, 2012 6:19 am |
mattvaretto wrote: |
Have you looked under the car and seen if it looks like there's anything missing? |
Yep - I had a quick look over and under and unfortunately I can't see anywhere obvious where it might have come from.
I haven't had a detailed look though - just wondered if anyone could identify it straight away as something really obvious.
If it's likely something to do with the cold air intake, from what others have suggested, then I guess a good look over from the right-hand side in and around the air filter is in order.
Posted: Mon Apr 23, 2012 6:27 am |
It's either the air intake, or the battery cooling pipe, both fit by right hand side of the radiator.
Posted: Mon Apr 23, 2012 6:35 am |
Looks like this bit. I know its not a 2.0hdi but the battery area is the same
Posted: Mon Apr 23, 2012 9:23 am |
Thanks - does look similar.
The car's out today but I'll check today or tomorrow around the battery and air filter box - lots of Googling for images based on air intake etc., based on the above, doesn't seem to throw up anything that looks the same...
Posted: Wed Apr 25, 2012 6:00 am |
