Latest: lio94
Overall: 17181
Online Now [81]:
Visitors: 81
Today: 14821
Total: 141325605
Forums › The Car › Request a how-to › Replacing the aerial (including base) (back mounted)
Forum IndexRequest a how-to
omricn
PostPosted: Wed Apr 25, 2012 9:50 am Reply with quote Up
Can someone please post a how to of removing the aerial base please?, my aerial is not removable at the moment because it's bolts are corroded and I have to replace the whole thing..
TNX Smile
MrZiggerz
PostPosted: Wed Apr 25, 2012 9:51 am Reply with quote Up
You do it, and take pictures and post how you did it Smile
omricn
PostPosted: Wed Apr 25, 2012 10:48 am Reply with quote Up
Actually I'm ordering a base right now, and that's exactly what I was thinking Smile that if no one will post a how-to than I will Smile
Squeaker
PostPosted: Wed Apr 25, 2012 12:10 pm Reply with quote Up
You need to pull the roof lining down a bit, then as you can see in this pict
The base has a bolt in it, there is just a nut which unscrews and the base should just lift off.
PostPosted: Wed Apr 25, 2012 1:38 pm Reply with quote Up
I can help fitting this with you my friend,give me a PM and I will tell you how to do it :D.
by the way,why it got 2 cables in this pic?
Squeaker
PostPosted: Wed Apr 25, 2012 3:10 pm Reply with quote Up
No idea why its got 2 wires Smile But it came off my Hdi Gti Smile
mtempsch
PostPosted: Wed Apr 25, 2012 11:27 pm Reply with quote Up
I'd assume actual antenna wire + a 12V line to power amplifier in the base
Silvermetallic 2004 206 RC
mastersonkev
PostPosted: Sun May 06, 2012 6:31 am Reply with quote Up
How do you remove the interior lining? I also need to replace my rear-mounted aerial.
Quiksilver 1.6 16V DOHC
  Quick Reply
Username:
Message:
Quote the last message
