Latest: heikkisj
Overall: 17126
Online Now [46]:
Visitors: 45
Today: 9718
Total: 100224130
Forums › The Car › 206 Talk › battery box question
Go to page 1, 2, 3  Next
Parkerspug
PostPosted: Thu Apr 26, 2012 1:03 pm Up
ive made a new battey box, which is currently getting sprayed up but when removing the old standard box i relised there was a plastic air feed pipe going into it!!!! anyone know what its for!!
Ryan
PostPosted: Thu Apr 26, 2012 1:16 pm Up
battery cooling duct?
Parkerspug
PostPosted: Thu Apr 26, 2012 1:18 pm Up
that needed lol!to late to get my box back from the sprayers!! Sad
Ryan
parkesie
PostPosted: Thu Apr 26, 2012 1:48 pm Up
Water egress Smile
Signature p**s
PostPosted: Thu Apr 26, 2012 1:55 pm Up
What does that box do that the original can't?
Rob2859
PostPosted: Thu Apr 26, 2012 2:03 pm Up
Its probably to allow any water that gets inside to drain out. Although I have fed wires through mine.
Parkerspug
PostPosted: Thu Apr 26, 2012 2:07 pm Up
box will just look better than the orginal one when its sprayed up!! having engine cover done at the same time Smile
if its for water i will drill a drainage hole in the bottom!
Ryan
PostPosted: Thu Apr 26, 2012 2:16 pm Up
Why would water get inside the battery box? The pipe is there to cool the battery.
Is it a good idea to put the battery inside a metal box?
PostPosted: Thu Apr 26, 2012 2:41 pm Up
Not if the car rolls-over, (touch wood).
Might be good to put some insulating material to the inside of the top-lid.
PostPosted: Thu Apr 26, 2012 2:56 pm Up
unless the road is total flat otherwise you will need some insulator or strap to stop the battery from moving...
Parkerspug
PostPosted: Sat Apr 28, 2012 11:29 am Up
All over that issue!! its got plastic all round to ensure no sparks occour and the top has been drilled and tapped to hold the battery in place!
Ryan
138Andy
PostPosted: Sat Apr 28, 2012 1:22 pm Up
surely that box would weigh considerably more than the original ? i just got my plastic one sprayed met black and it looks nice :/
gazza82
PostPosted: Sat Apr 28, 2012 1:47 pm Up
It's a cooling pipe .... batteries do get warm and in a metal box, it's liable to get a lot warmer ...
PostPosted: Sat Apr 28, 2012 2:30 pm Up
Seems a bit of a chocolate teapot idea. Doesn't do anything the original can't and can't see it looking better either.
Parkerspug
PostPosted: Sun Apr 29, 2012 10:40 am Up
its different yea but that is what modifing is all about!!! defo lighter as its made from 18 guage alu!! each to there own spose!! just gies my 180 a personal touch! rant over ....................
Ryan
Page 1 of 3
