Latest: Andyblue64
Overall: 17123
Online Now [335]:
Visitors: 334
Today: 73309
Total: 98442024
Forums › The Car › 206 Talk › Picy of rear brake compensator?
PostPosted: Mon Apr 30, 2012 1:24 am Up
Recently found the clonking noise from the rear brakes was the compensator valve spring becoming totaly loose. oops.
I have repaired and re-tightened it but would like to have a look at how
stretched it is normaly so a pic would be appreciated just to get an idea.
Cheers.
dj71
PostPosted: Mon Apr 30, 2012 2:00 am Up
dj71
PostPosted: Mon Apr 30, 2012 2:53 am Up
Cheers mate.
You might want to put some WD40 on there, it looks a bit rusted and might be seised.
Anyone else have a pic?
PostPosted: Mon Apr 30, 2012 9:54 am Up
Nope, mines got EBD so no compensator valve Laughing
PostPosted: Mon Apr 30, 2012 10:10 am Up
Yep, the 'other' one has no valve either so I can't compare.
Anyway I tightened it now and seem to have rear brakes again.
So much for KTEO (Greek MOT), which it passed with flying colours..
PostPosted: Mon Apr 30, 2012 11:18 am Up
Never knew the Titanic had a compensator valve.
PostPosted: Mon Apr 30, 2012 12:15 pm Up
It didnt work if it did!
