Latest: tbafonso
Overall: 17130
Online Now [274]:
Visitors: 272
Members: 1
Today: 40060
Total: 103902203
Forums › The Car › 206 Problems › Mis-fire/Running on 3
Go to page Previous  1, 2
Tiago
PostPosted: Tue May 01, 2012 9:56 am Up
Update: Went to the local scrap yard, and found a Sagem coil pack and tried that, car still misfired so now that's out of the way it's safe to say it is the injector? Why would the fault code come up with number 3 when it was determined that it is number 4?
Razor34
PostPosted: Tue May 01, 2012 10:36 am Up
Sagem coil packs are a known problem. I changed my recently for a Bourgicord one from GSF Car Parts = no more problems. Bosch spark plugs as well!!!!
Ray
Tiago
PostPosted: Tue May 01, 2012 12:45 pm Up
I have a bougicord one currently, the one at the scrapyard was Sagem and I didnt buy it because the problem was still there.
I have took the injectors out now and was going to swap them and see if anything changed but I lost the o ring for one, just my luck.
dj71
PostPosted: Wed May 02, 2012 4:56 am Up
any update for this prolem yet? as i have a similar issue with mine, change the coil but still no joy
dj71
Tiago
PostPosted: Wed May 02, 2012 7:12 am Up
Update
Just swapped over injector #4 with #1 (nearest to gbox) and unplugged the one I thought was faulty and no change to engine working order. unplugged number 4 and it was even worse.
So it is safe to say I have a dodgy injector, ordered a new one!
PostPosted: Wed May 02, 2012 1:48 pm Up
so did you fitted it or not yet??i mean the new injector,if you did,have this fixed it Smile
Tiago
PostPosted: Thu May 03, 2012 2:07 am Up
Not yet, I just phoned the shop and it's just arrived so going to go pick it up, fit it and I shall update this once again Smile
Tiago
PostPosted: Thu May 03, 2012 3:48 pm Up
After receiving the wrong injector from the supplier and having to order a new one, it managed to be delivered today and i got it fitted.
This solved the problem Smile
PostPosted: Thu May 10, 2012 1:43 pm Up
glad to hear that mate Very Happy
pug206lx
PostPosted: Thu May 10, 2012 3:31 pm Up
I was about to say washer jet leaking on the injector and killing the injector. Glad you sorted it. My old 206 1. 4 had this problem and so did my sisters 1.4. Both on no.4
Page 2 of 2
