Posted: Mon Apr 30, 2012 1:24 am |
Recently found the clonking noise from the rear brakes was the compensator valve spring becoming totaly loose. oops.
I have repaired and re-tightened it but would like to have a look at how
stretched it is normaly so a pic would be appreciated just to get an idea.
Cheers.
Posted: Mon Apr 30, 2012 2:00 am |
Posted: Mon Apr 30, 2012 2:53 am |
Cheers mate.
You might want to put some WD40 on there, it looks a bit rusted and might be seised.
Anyone else have a pic?
Posted: Mon Apr 30, 2012 9:54 am |
V9977 wrote: |
Anyone else have a pic? |
Nope, mines got EBD so no compensator valve
Posted: Mon Apr 30, 2012 10:10 am |
MrBSI wrote: |
V9977 wrote: |
Nope, mines got EBD so no compensator valve |
Yep, the 'other' one has no valve either so I can't compare.
Anyway I tightened it now and seem to have rear brakes again.
So much for KTEO (Greek MOT), which it passed with flying colours..
Posted: Mon Apr 30, 2012 11:18 am |
Never knew the Titanic had a compensator valve.
Posted: Mon Apr 30, 2012 12:15 pm |
Edward wrote: |
Never knew the Titanic had a compensator valve. |
It didnt work if it did!
