Latest: Worthy967
Overall: 17143
Online Now [507]:
Visitors: 506
Today: 96065
Total: 115740326
Forums › The Car › 206 Problems › Remove key but engine still running.
sulli
PostPosted: Sun Apr 29, 2012 10:44 am Up
This happened to me about a month ago, just thought it was the car throwing and jidd, so let it slip by. But it has happened to me today as well I removed the keys and the engine is still running and drivable, i put them back in/out still no difference. To turn the engine off i had to stall the car, just been back out 10 minutes later and the car turns on and off fine, really starting to bug me now as i cannot work out what it is, I've noticed on both occasions it has done it it has been on a long run. All help appreciated Thank you.
206 VAN SILVER!
www.Sheffield-WebDesigns.co.uk - discount for 206info members!!
www.HealthyCigs.co.uk - discount for 206info members!! quote - 206info
PostPosted: Sun Apr 29, 2012 10:46 am Up
Check the fuel relay.
Battery light come on when it carries on running?
sulli
PostPosted: Sun Apr 29, 2012 10:47 am Up
Nope, no lights out of the usual? Sorry for being a novice will you expand on the fuel relay. Thanks.
206 VAN SILVER!
PostPosted: Sun Apr 29, 2012 10:48 am Up
Big brown relay under the ECU, turns fuel on and off.
sulli
PostPosted: Sun Apr 29, 2012 10:49 am Up
Ok, do i replace this? or just check it? :S thanks.
206 VAN SILVER!
PostPosted: Sun Apr 29, 2012 11:02 am Up
Pins 8 and 5 should be 0ohms when battery is connected (+12 pin1, and -ve pin7)
Infinity when battery d/c
sulli
PostPosted: Sun Apr 29, 2012 11:11 am Up
Sweet, will check em, Thanks Lee!!
206 VAN SILVER!
PostPosted: Mon Apr 30, 2012 7:47 am Up
Also, it might be the key-ignition switch contacts getting fused (stuck closed) as there was an Info-flash
from Peugeot about this and they changed spec of the part subsequently.
rick-gti
PostPosted: Mon Apr 30, 2012 7:56 am Up
Just thought i would say my brothers corsa did this and we found it to be the ignition barrel was worn. The car could be started with anything flat that would fit into the ignition.
clio 197sport owner
Ash
PostPosted: Mon Apr 30, 2012 9:20 am Up
youtu.be/wYaXw8TZEvs?t=6m9s
colinn
PostPosted: Mon Apr 30, 2012 1:31 pm Up
haynes gives 4 possibilities for engine running on:
- excessive carbon build-up in engine
- high engine operating temp
- engine management system fault - petrol models
- fuel injection pump fault - diesel models
sulli
PostPosted: Mon Apr 30, 2012 3:28 pm Up
Thanks mate!
206 VAN SILVER!
ldare2000
PostPosted: Tue May 01, 2012 1:52 pm Up
I had this after jump starting...... I had to replace the ECU Sad
Lou
ldare2000
PostPosted: Tue May 01, 2012 1:53 pm Up
Forgot to say, I tried stopping by stalling however my ECU was still live so would drain the battery over night.
Lou
PostPosted: Tue May 01, 2012 3:06 pm Up
^^?? Are you sure thats right? I doubt the ECU would driain the battery, stalling would not cause a fault with the ECU?
