Online Now [61]:
Visitors: 60
Today: 2205
Total: 116738489
Forums › The Car › 206 Talk › Obd reader from eBay
Spiky
PostPosted: Sat May 05, 2012 6:49 am Up
Looking for a cheap obd reader, to read any codes that maybe on my 206 from time to time
It's 2000 x 2.0L hdi
Which one do I need to get?
Anyone got any suggestions
I also have a 2006 focus c-max diesel, so would be ideal to read that too, If possible
206 HDI Dturbo X/2000
PostPosted: Sat May 05, 2012 7:08 am Up
The Focus will be easy to source a reader for as its a 2006 model which means it has to be EOBD be law & you can pick basic engine fault code readers up anywhere cheaply enough.
The 206 you have being a year 2000 will need a more expensive code reader / tool as its not EOBD even though it has the same type of diagnostic socket.
PostPosted: Sat May 05, 2012 7:14 am Up
I was looking a while ago because the saxo wasn't compliant with my OBD2 reader (I think it's 98 reg)
When I looked pretty sure this was the cheapest decent kit to get - bearing in mind I just searched for it now so could be cheaper elsewhere
www.ebay.co.uk/itm/Lex...2ebdc392b5
Don't know about only code readers as I always use a laptop
Spiky
PostPosted: Sat May 05, 2012 10:57 am Up
A system that works with a laptop is ok for me as long as I can get the software from somewhere Smile
Cheers for info guys
pro_steve
PostPosted: Sun May 06, 2012 3:01 am Up
£85 is a very good price for that piece of kit. Very handy to have it!
www.hdi-tuning.co.uk
PostPosted: Sun May 06, 2012 7:05 am Up
Also cheap China s**te.
I'd rather pay a bit extra for quality when using tools of this nature!
Razor34
PostPosted: Sun May 06, 2012 2:07 pm Up
I bought a OBDII reader recently off ebay and it has served me a treat with the codes I had up and only paid £13 as well - bargain!!!
Ray
Spiky
PostPosted: Sun May 06, 2012 2:10 pm Up
Got a link?
PostPosted: Sun May 06, 2012 2:13 pm Up
That will be an OBD-II, like said even though you have the same type of diagnostic socket you will need a PRE OBD-II scanner
Razor34
PostPosted: Sun May 06, 2012 2:15 pm Up
Not a link as such as I got this from a private seller but this is the one I got:
Car Diagnostic Scanner CAN-BUS Fault Code Reader OBD2 OBDII EOBD EOBDII U480 UK
Ray
Spiky
PostPosted: Sun May 06, 2012 2:24 pm Up
Cheers
