Posted: Mon Apr 20, 2015 6:01 am |
[quote="spike_202"]
arent these turned the wrong way? tinier part should be facing downside?
Posted: Thu Jun 18, 2015 5:20 pm |
[quote="neoluz"]
spike_202 wrote: |
arent these turned the wrong way? tinier part should be facing downside? |
No they can go both ways, but as the bonnet in this particular area is double skin it was easier fitting them this way.
Also they look better this way lol
Posted: Tue Jun 30, 2015 5:23 pm |
*Note to self*
1/7/15
X2 eibach pro line.
X2 top mounts.
X2 drop links.
X2 rear discs.
X2 rear pads.
X2 hand brake cable.
X1 exhaust rubber.
Oil and filter + (new plug and washer).
Gearbox oil + (new plugs and washers).
Clean down and re-oil air filter.
Posted: Mon Jul 20, 2015 5:18 pm |
BBM group N mounts from pug1off. Top mount/gearbox mount and buffers to match my already fitted bottom mount.
Posted: Sat Nov 07, 2015 6:00 am |
I'm done with Baker mounts...Rubbish quality, they keep breaking, squeaking etc. We've replaced 3 sets of top mounts already.
Hopefully I'll have more luck with Vibra Technics.
Posted: Fri Nov 18, 2016 9:15 pm |
wow this is a blast from the past, its still sitting on my drive just getting it ready for the winter it's been sat still for a while at as moved house / baby / work / new car so it's just been waiting for me to jump in again. I think one of my top mounts that I fitted has gone either that or its eaten another wheel bearing lol
Posted: Fri Nov 18, 2016 9:20 pm |
Welcome back to the mate.
Got email notification right out about this awesome thread of yours that I've been following Will you get the pug back on the road then
Posted: Fri Nov 18, 2016 9:35 pm |
lol yer this was a DD I used it every were everyday. but since I've got a new 308, having bucket seats and no rear seats isn't good with a 8month old haha.
I've got the flat sorted just need to identify what the grinding noise is. IIRC it was while on full lock to the right. at the time I put it down to a top mount but I'll take it to me mates garage all it needs is an MOT then I'll use it.
Posted: Sat Nov 19, 2016 11:57 am |
Got any upto date pictures? Is it sat rotting away? Do you know how your rev counter is connected to your ECU? Is it spliced directly into the clocks?
Posted: Mon Jan 09, 2017 8:33 pm |
I haven't used it since before Xmas as MOT has ran out. rotting away it certainly isn't but needs a wash think I need either a new wheel bearing or top mount on the passenger side.
rev counter is loomed to the euc is all I can tell you mate, pug1off did all the wiring so I wouldn't know. I literally haven't had to touch anything since I've had my work done (nearly 8 years ago) just the mods for more power ect.
Posted: Mon Jan 09, 2017 8:38 pm |
Posted: Sat Feb 11, 2017 5:29 pm |
few more bits spare dash to get flocked.
carbon fibre bonnet needs some tlc and bonnet catches fitting.
Posted: Sun Feb 12, 2017 6:38 pm |
you sort out a steering wheel yet Rich? That bonnet looks familiar off Steve Thody?
Posted: Sun Feb 12, 2017 9:45 pm |
MattyP wrote: |
you sort out a steering wheel yet Rich? That bonnet looks familiar off Steve Thody? |
not yet I'm just looking for bits atm it's on my list of things to do lol. I most likely will go OMP boss and wheel.
nah the bonnet was of a kid called Travis from Nottingham? (Facebook find) it's not in bad condition 2bh needs a relacquer and bonnet pins put in.
Posted: Sun Feb 12, 2017 9:59 pm |
spike_202 wrote: |
MattyP wrote: |
nah the bonnet was of a kid called Travis from Nottingham? (Facebook find) it's not in bad condition 2bh needs a relacquer and bonnet pins put in. |
He must have bought off Steve as it's still got the club sticker from when it was on his car lol
Sweet! Can't wait to see all the flocked bits fitted
