Posted: Sun Mar 10, 2013 10:48 am |
Had this fault a little while ago along with a misfire .. so basically i put it into the garage and a week later i'm told it was a blown head gasket due to a leaking water pump housing at the back of the engine which leaked into the engine and caused the head to go .. soo all is well and yesterday i gets the warning light again when starting up .. no misfire this time tho .. its a p1327 .. ive just fitted a new coil pack so i know its not that .. any ideas? sumbody suggested crank sensor
cheers
Posted: Sun Mar 10, 2013 11:50 am |
One thing, leaking water pump will cause a lack of coolant causing the engine to get hot CAUSING the headgasket to fail. Not leaking coolant into engine causing it to fail. That or its a load of b******s.
Your code, after a little digging, is it a sageam coilpack by anychance?
| Team Impossible Possible
Posted: Sun Mar 10, 2013 12:40 pm |
hmm did have a feeling the mecchy was full of s**t tbh as i thought the same as you .. nah its not a sagem
