Posted: Fri May 11, 2012 4:07 am |
right i have been offered a ci tuning basic turbo conversion kit, only the stage 1 turbo kit, my mate offered it me for 500, its around 2500 on the website, hes got everything which is in the kit, they say its a straight bolt on kit which runs 6psi of boost, they also say you don't have to do no engine management or internal modifications, people are saying tho you need to remap the ecu, so i don't know what to believe, how does it work, the turbo kit is for a saxo vtr but will fit on the 206 xs 1.6 8v as they are identical engines, any uphands on this?
Posted: Fri May 11, 2012 4:15 am |
Your friend isn't Gav is it by any chance..?
Posted: Fri May 11, 2012 4:19 am |
no mate, he lives just up the road from me, but has this gav done this to his car, i just want to know if i can put this kit on my car and do nothing else and still get around 30-40bhp as they say?
Posted: Fri May 11, 2012 4:31 am |
Ring your insurance 1st and see if it's worth it.
Posted: Fri May 11, 2012 4:57 am |
ah they wont know
Posted: Fri May 11, 2012 5:01 am |
Adam2061994 wrote: |
ah they wont know  |
Then your just a total c***
Standard compression would be too high for any boost, does the kit include a decompression plate?
ah they wont know  |
Ahhhh... Here we go.
I am keeping my mouth shut for the time being.
Posted: Fri May 11, 2012 5:06 am |
its okay mate im only messing haha! its extra 300 quid :L
Posted: Fri May 11, 2012 5:07 am |
Posted: Fri May 11, 2012 5:15 am |
Andrewxps wrote: |
Standard compression would be too high for any boost, does the kit include a decompression plate? |
It's fine for a small amount of boost.
Posted: Fri May 11, 2012 5:23 am |
mattie done that before, and the engine blown up after 3 months?
Posted: Fri May 11, 2012 6:03 am |
For the £800 (turbo and insurance) you coult just sell your xsi and buy a gti and not have the reliabilty issues you will come accross by fitting the turbo. Also doesn't sound like you know what your doing so I wouldn't be attempting the turbo fit as every problem you come accross will need looking at by a garage.
Posted: Fri May 11, 2012 7:28 am |
Posted: Fri May 11, 2012 7:48 am |
Trade Rating: +16
