Latest: lio94
Overall: 17181
Online Now [340]:
Visitors: 339
Today: 78941
Total: 141634297
Forums › Tuning, Modification & Legal › Project Cars › SINFUL DESIGN GTi 180 Track Project
Go to page Previous  1, 2, 3 ... 13, 14, 15, 16  Next
PezHdi
PostPosted: Sat Mar 29, 2014 1:56 pm Up
That's sick mate Smile got a lot of time for this thread Smile
EXL Pez
SinfulDesignCom
PostPosted: Sat Apr 05, 2014 12:53 pm Up
...finally got the Omex unit fitted and configured. After a LOT of d*cking about, I have got the shift light exactly where I wanted it at 6.8k and with adjustments of 100 at my fingertips. I won't explain here, but should anyone want to get a shift light fitted, I will happily explain the science... Very Happy
[align=center]
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
GlennMRX
PostPosted: Sun Apr 06, 2014 2:59 am Up
This is stunning!! Hope my XS turns out this well!
SinfulDesignCom
PostPosted: Sun Apr 06, 2014 4:41 pm Up
Thank you! Was so happy with it all working so I ordered some lovely velour mats earlier today - just to complete the look Smile
JamieM
PostPosted: Mon Apr 07, 2014 2:51 am Up
Looks wkd mate,
So you can fit the omex on the 180! I was lead to believe it wouldn't fit! looks tidy,
Also can't wait to get my wheel now looks swish!
Aegean Blue 206 GTi180
SinfulDesignCom
PostPosted: Mon Apr 07, 2014 8:30 am Up
Cheers Jamie.
Yes, the Omex eventually went to plan, but only as a shift light - the rev limiter will not work on the coil pack. It is a simple question of mathematics to get the shift point where you want. Let me know if you ever get round to fitting one and I will explain.
mattymj
PostPosted: Wed Apr 23, 2014 12:18 pm Up
Hi after reading through this tread I decided to check my front spax shock as I've always wondered if they are the correct way around.
Here's how mine looked in comparison
I know the picture is small but shows direction
SinfulDesignCom
PostPosted: Wed Apr 23, 2014 5:17 pm Up
Something not right here. Your spring is not correctly seated; that is your first clue.
The springs spiral counter-clockwise upwards, the end of which should seat in the point where it slopes. It would be difficult to notice THAT much difference with a standard setup, but its nonetheless not safe as your spring is taking more load on one side.
Try jacking the car up and spinning the spring round to see where it seats, but I would put good money on this set up being wrong. Bear in mind that if it seats correctly, you may still need to check the top bearing and at that point you might have already realised you have the wrong spring for the car!
Bigbenj_08
PostPosted: Thu Apr 24, 2014 2:57 am Up
SinfulDesignCom wrote:
[align=center]
That steering wheel is awesome!
Aegean Blue 1.6 16v Sport
SinfulDesignCom
PostPosted: Thu Apr 24, 2014 8:41 am Up
Cheers Ben. Am very happy with it myself - really looks the part and is great to drive with. The boss brings the whole apparatus closer to the driver which really helps with the harness arrangement.
PostPosted: Thu Apr 24, 2014 9:22 am Up
looks awesome mate, the only black 180 which is better than mine lol would you say the omp wheel you've got fitted would be just as good with factory seats?
Bigbenj_08
PostPosted: Thu Apr 24, 2014 12:18 pm Up
Is it any bigger/smaller than a standard wheel?
It looks the business!
I'd love something like this and a flocked binnacle (just for the look), but 1) no idea what size and 2) MOT reasons put me off as I'm not sure I can legally remove the standard wheel with airbag!
SinfulDesignCom
PostPosted: Thu Apr 24, 2014 2:53 pm Up
Cheers Matty - and I have the factory 180 seats with my harnesses. They are very good seats IMO. Not really worth changing unless you need FIA.
Ben - it is smaller than standard - is 320mm diameter. The rules for MOT are a nightmare. I started a post a while back when I was MOT'ing mine. It went through, as it should have done, as a track car and thus did not need to be tested for airbags. I will be fine for the future as long as they don't change it.
To be classed as a track car, you need to have significantly changed the car from original spec, and HAS to include specific items. Its done on something akin to a points system, or which you have to have enough points to be classes as a track monster. Harnesses and rear seat delete mod goes a long way and swung mine, but then so did non standard brakes, suspension, filtering blah blah....
Let me know if you want more info and I will send a request to my long-term memory... Smile
PostPosted: Thu Apr 24, 2014 4:35 pm Up
sorry mate, i meant, if you were to use the car as a daily would you still use the omp steering or would you stick with the factory unit?
SinfulDesignCom
PostPosted: Thu Apr 24, 2014 6:18 pm Up
The problem with the aftermarket boss is that it brings the wheel further away from the cowl meaning the stalks are further away. As you don't use them on a race day, it doesn't worry me, but for a daily drive this could be frustrating. Maybe you could find a shallower boss kit, but I went with the original item and this is te upshot...
Page 14 of 16
