Latest: Worthy967
Overall: 17143
Online Now [556]:
Visitors: 555
Today: 87044
Total: 114210661
Forums › The Car › 206 Problems › WHEEL BOLT PROBLEM 308 ALLOYS ON MY 206
Gazz206
PostPosted: Sun May 13, 2012 6:10 pm Up
hi im new to the site, i bought a 206 about 2weeks ago any mine come with 308 sport wheels on, they should be 225/ 17 tyres standard but the old owner has put 205/40/17s on also has wheel spacers, but when i removed the wheel to change a wheel bearing the wheels were only holding on by a few threads on the wheel nuts, so its un safe, ive tryed every were to find longer bolts so i can use these alloys on my 206 again they are flat seat type wheel bolts, could anyone help me out on finding new wheel bolds flat seat type but longer than standard size thanks thanks gaz
GTI
PostPosted: Sun May 13, 2012 6:20 pm Up
You are going the hard way about it all. Remove the spacers, job done.
They are not needed.
Uz
PostPosted: Mon May 14, 2012 2:01 am Up
Firstly theyve got the right tyres on the wheels. 225 width tyres would have scrubbed on full lock like a fat ladies thighs.
That aside. If your after flat seated bolts on eBay look for 55mm Peugeot bolts. The longer thread length OEM bolts only come in that length and then you have to grind them down to your desired length.
308s have different offsets light to the 206 which is why there's spacers fitted to them as iirc 308 have et34 upwards, which would mean theyd catch on the spring seat on the strut.
What size wheel spacers are on the car..? Also what type..? As this could be the cause of wheel bearing damage.
PostPosted: Mon May 14, 2012 3:51 am Up
I found that the 308 PcD was 27. Shoul be fine on a 206.
Gazz206
PostPosted: Mon May 14, 2012 7:01 am Up
just has standard 4-5mil spacers ive looked every were for bolts as they need to be flat seat but still have a lip on the bolt witch sits on the inside of the wheel
GTI
Uz
PostPosted: Mon May 14, 2012 7:04 am Up
Hmm...thats fair enough then, was looking at servicebox the other day and certain wheels were showing that offset.
You should have a problem with 5mm spacers and standard bolts. But...
www.ebay.co.uk/itm/OE-...45fea405db
Gazz206
PostPosted: Mon May 14, 2012 7:05 am Up
these are type i need but longer, can anyone help me
www.ebay.co.uk/itm/150...1423.l2648
GTI
gazza82
PostPosted: Mon May 14, 2012 12:48 pm Up
What about these ... flat pug wheel bolts ... ???
Uz
PostPosted: Mon May 14, 2012 12:57 pm Up
I've already posted those but as a set of 16.
Gazz206
PostPosted: Mon May 14, 2012 2:20 pm Up
i dont think they will work as they ant got the flang part that sits in the centre of the alloy
GTI
PostPosted: Mon May 14, 2012 2:25 pm Up
They will. If Uz gives you alloy advice. Take it.
gazza82
PostPosted: Tue May 15, 2012 3:22 pm Up
Wasn't copying ... I sent mine within a minute of yours! Wink
PostPosted: Tue May 15, 2012 3:58 pm Up
What about a locking nut?
Gazz206
PostPosted: Tue May 15, 2012 5:32 pm Up
ive sold the wheels today to much hassel im going to buy some 206 gti's insted
GTI
