Online Now [342]:
Visitors: 340
Members: 1
Today: 93264
Total: 154479670
Forums › The Car › 206 Talk › Front discs on a HDi?
Forum Index › 206 Talk
lmilligan
PostPosted: Tue May 15, 2012 3:32 am Up
Morning all, brought some new oem brembo discs off eBay the other day and now they are asking me a question which I don't know.
Please could you check the overall height of the discs you need?
The part number you have ordered are 266mm diameter and overall height is 27.4mm
We ask this question as there are another set of discs for the car with 266mm diameter but the overall height (the hub) is larger at 34.2mm
Anyone know what ones I need? Car is an 05 plate HDi 2.0. (I can't check Myself I'm at work now Razz
Thanks Smile
PostPosted: Tue May 15, 2012 3:37 am Up
as it said, there is 2 types of calipers which run 266 disc, you need to check it yourself.....
both are fitted on gti, 1.6 16v and 1.6/2.0 HDi.
but most likely yours will be 266x22 disc with 34mm offset
glenpring
PostPosted: Tue May 15, 2012 5:30 am Up
check service box it tells you on there
lmilligan
PostPosted: Tue May 15, 2012 5:47 am Up
Servicebox says diam 266 ep22
PostPosted: Tue May 15, 2012 6:17 am Up
Did you get that from your vin number as has been said there are 2 types
lmilligan
PostPosted: Tue May 15, 2012 6:23 am Up
Yeah got it from the vin mikey and got the right ones coming now Smile
