Posted: Tue May 15, 2012 7:12 am |
Noticed yesterday when looking at the trackrod end on the N/S that there's a small split in the cv boot
Not sure what to do, i can either swop the driveshaft for another i have or put a new boot on. What do people think will be easiest. Dont really want to pull the driveshaft out the box as i have only just filled it up with oil. But i have never changed a cv boot before and it looks abit tricky to get the small end over the end of the shaft.
Posted: Tue May 15, 2012 7:16 am |
I'd just change the cv boot.
Posted: Tue May 15, 2012 12:13 pm |
Does the outer part of the driveshaft come off the shaft?
Posted: Wed May 16, 2012 11:54 am |
Anyone no the best way to put the outer cv boot on? Does the end of th shaft come off?
Posted: Wed May 16, 2012 12:13 pm |
if your not competent in changing a cv boot then just buy a complete shaft
costs range from £30 ish and is a straight out and replace although you probably want a driveshaft seal aswell
im just doing a cv myself which comes with a new boot for £17. Easy job just watch this www.youtube.com/watch?v=-S-ofMoWsr0
goodluck
Posted: Wed May 16, 2012 12:53 pm |
Posted: Wed May 16, 2012 1:06 pm |
I wont be able to do it like that. I have just fit the engine and filled the gearbox up with oil. So I dont really want to have to drain it and buy new oil.
Ive done them before but have been off the car.
