Latest: lio94
Overall: 17181
Online Now [237]:
Visitors: 236
Today: 52844
Total: 142003366
Forums › The Car › Request a how-to › rear axle bearing
rear axle bearing
Forum IndexRequest a how-to
Adz2598
PostPosted: Thu May 17, 2012 10:34 am Reply with quote Up
any 1 changed these before or know how to do this or how easy/it is,
white 206 hdi
PostPosted: Thu May 17, 2012 10:53 am Reply with quote Up
it's pain in the a$$ job Sad
Adz2598
PostPosted: Thu May 17, 2012 11:11 am Reply with quote Up
worth just getting a whole new axle ?
white 206 hdi
PostPosted: Thu May 17, 2012 11:26 am Reply with quote Up
if your confident with your mechanical skills and have patience it isnt too bad a job but if your in any doubt id get a 2nd hand axle.
just find a lot of good axles are being thrown away because people cant be a**e to change the bearings it doesnt always ruin the stub. i rebuilt mine over the winter was only on 65k but i thought id do it as a matter of course while i was adjusting the rear height so i know the axle will stay good
PostPosted: Thu May 17, 2012 11:37 am Reply with quote Up
If you need an axel ive got one off the gti im breaking.
PostPosted: Thu May 17, 2012 11:52 am Reply with quote Up
I'd look at repairing your existing axle even if the bearings and stub pins are knackered.
HDI90
PostPosted: Thu May 17, 2012 12:01 pm Reply with quote Up
Quite easy if everythink go,s to plan and the bearing hasnt worn the shaft egg shaped!
GTI 180
PostPosted: Thu May 17, 2012 12:21 pm Reply with quote Up
better to re-con it than getting a scrap yard axle
usher
PostPosted: Thu May 17, 2012 12:51 pm Reply with quote Up
would be interested in this also as i have no clue really where bearings etc are
will be doing it soon
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Thu May 17, 2012 1:12 pm Reply with quote Up
My bearings are fine, there's no play in the arm yet it has dented the bearing surface on the stub axle...so if you think its a case of just sticking new bearings on a worn axle then be prepared for a surprise. In other words if you have an evidently worn axle with play in the bearings it will be worse than mine.
there is a guide on here so as on youtube... Laughing
usher
PostPosted: Thu May 17, 2012 3:19 pm Reply with quote Up
just done a search on youtube seams to be a few guides so might use them as a guide, is it worthwhile changing all bearings etc
i will be changing the mount bushes as they are shot, any special tool needed, also is it easier to remove the tbs while the axel is off the car
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Thu May 17, 2012 3:54 pm Reply with quote Up
i am struggle to remove the bush...
bearing is easy, definitely worth to do it if you want to keep the car for at least few more year
usher
PostPosted: Fri May 18, 2012 11:40 am Reply with quote Up
his it possible to change the bushes with normal tools or do you need a press to get them in
project thread WIP
garage
FAQ
206 gti firedance
spike_202
PostPosted: Fri May 18, 2012 12:45 pm Reply with quote Up
Why not buy a 2nd axle and re-build it then swap it over? Then you could rebuild your old one and sell it or scrap it??
**spike's project**
TEAM:+200bhp
  Quick Reply
Username:
Message:
Quote the last message
