Latest: lio94
Overall: 17181
Online Now [85]:
Visitors: 84
Today: 7876
Total: 141505251
Forums › The Car › 206 Problems › Drivers side indicator flashes fast
Kelz
PostPosted: Wed May 23, 2012 4:55 pm Up
As above my drivers side indicator flashes fast for some reason, Passenger side is fine and when I do the hazards they flash as normal both sides
It's only when I am actually indicating to turn right.... Also I have checked all bulbs and they are all fine and working
Kelz!
btownsend06808
PostPosted: Wed May 23, 2012 5:09 pm Up
Have you changed the bulb recently as if the bulb is wrong eg the pins it can cause this
MrZiggerz
PostPosted: Wed May 23, 2012 5:28 pm Up
Usually that's a blown bulb.
PostPosted: Wed May 23, 2012 5:31 pm Up
There might be a led equivalent bulb fitted on either the front or back.
Or the bulb might be so old, it's resistance has gone-up so much (>dim light) BSI thinks it's blown.
Hazards are not checked for blown bulbs btw.
Kelz
PostPosted: Thu May 24, 2012 7:43 am Up
Ok I will get a couple of new bulbs tomorrow or Saturday and see if that makes any difference
Many thanks people
Kelz!
