Latest: heikkisj
Overall: 17126
Online Now [43]:
Visitors: 42
Today: 4577
Total: 100337617
Forums › The Car › 206 Talk › 180 cambelt change
180 cambelt change
Go to page Previous  1, 2
enfantprodige
PostPosted: Thu May 24, 2012 8:51 am Up
Seabook wrote:
you better change the pump as well if you want to keep the car for let say more than a yr.
if the pump seized that the car can be write off
Guys, I changed the cambelt once (about 5 years ago, the car had about 35k miles, as I've been told that it needed to be changed), but I haven't changed the pump (I've got a 1.4 petrol).
Today (5 years later) the car has about 70k miles and is 10 years old, and I've never had problems with the pump.
Now, I don't know if the 180 is a different story...
Big_Rich180
PostPosted: Thu May 24, 2012 8:58 am Up
Its just luck of the draw mate, its the same with any wearing part really, but if the water pump had gone a week after you'd done your cambelt you would have kicked yourself.
Jammie_1989
PostPosted: Wed May 30, 2012 10:12 am Up
Didn't have the pump changed on mine. Machinic said is was all tight and as new so there was no point. All depends on what the pump is like tbh suppose better safe than sorry but if its as tight as a new one could just be a waste of £50
206 gti 180
ramigojag
PostPosted: Wed May 30, 2012 10:59 am Up
id always do the pump with the cambelt because it might feel tight and fine but its the extra tension and the change in tension from the old to the new belt which will then cause it to wear much quicker
gaffa786
PostPosted: Wed May 30, 2012 1:16 pm Up
Just had my cambelt changed on my 1.4 anfld they tightend it too much and sounds funny now Sad
PostPosted: Wed May 30, 2012 1:22 pm Up
TU cambelt, cant get much easier to do then that ( only Ford CVH )
FYI a Peugeot main dealer technician will be able to do a TU cambelt on a 206 in under 45 minutes Laughing
Johnbyron
PostPosted: Wed May 30, 2012 2:02 pm Up
I'm not changing the pump any more because when you think about it a new pump could be just as bad as the one already fitted, because the new pump may not be as good quality, fair enough if the one that is currently fitted has any play etc etc then I shall change it
Page 2 of 2
