Latest: lio94
Overall: 17181
Online Now [165]:
Visitors: 164
Today: 19287
Total: 141269663
Forums › The Car › 206 Problems › 206 power steering oil change?
nellyhaggis
PostPosted: Thu May 24, 2012 3:34 pm Up
Power steering oil needs to be changed.
Has anyone done it before as I ain't 100% on how to go it.
Cheers.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Thu May 24, 2012 3:38 pm Up
you need an oil syringe to suck the old fluid out as there is no drain plug in the system.
spike_202
PostPosted: Thu May 24, 2012 4:03 pm Up
Could the pipe at the bottom of the resivor be undone and let it drain out that way?
**spike's project**
TEAM:+200bhp
gaffa786
PostPosted: Thu May 24, 2012 4:07 pm Up
is the power steering fluid same as automatic transmission fluid?
ramigojag
PostPosted: Fri May 25, 2012 12:15 am Up
^ its the same fluid yes but run on two seperate systems
nellyhaggis
PostPosted: Fri May 25, 2012 12:40 am Up
Is it possible to take a pipe off the rack to bleed the oil out?
