Posted: Thu May 24, 2012 3:34 pm |
Power steering oil needs to be changed.
Has anyone done it before as I ain't 100% on how to go it.
Cheers.
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Thu May 24, 2012 3:38 pm |
you need an oil syringe to suck the old fluid out as there is no drain plug in the system.
Posted: Thu May 24, 2012 4:03 pm |
Seabook wrote: |
you need an oil syringe to suck the old fluid out as there is no drain plug in the system. |
Could the pipe at the bottom of the resivor be undone and let it drain out that way?
Posted: Thu May 24, 2012 4:07 pm |
is the power steering fluid same as automatic transmission fluid?
Posted: Fri May 25, 2012 12:15 am |
^ its the same fluid yes but run on two seperate systems
Posted: Fri May 25, 2012 12:40 am |
Is it possible to take a pipe off the rack to bleed the oil out?
