Posted: Wed Feb 15, 2012 2:57 pm |
i have looked through other problems in relation to overheating but could not find one with help to a problem i have, if there is one then i apologise for missing it, anyhow would someone please check out the following video and watch the gauge as i turn the heater on full heat and off again, then please advise, thanks very much.
Debs
IGNORE THIS FACEBOOK LINK AND USE THE ONE FURTHER DOWN THE PAGE, Thanks
www.facebook.com/photo...permPage=1 206 overheating and my video link on facebook
| | ![](images/spacer.gif) |
Posted: Wed Feb 15, 2012 3:03 pm |
Cannot access your FB.
Posted: Wed Feb 15, 2012 3:28 pm |
The problem started earlier today after a short journey of approx 2 miles, i noticed the temp needle had reached into the red and so i put on the heater to try and bring down the temp but nothing happened, the engine fan did not come on and after arriving back home i left the car to stand for over 2 hours before checking the oil and water levels but both were okay, i then started the engine from cold and it had only been running for maybe 5 minutes max and thats when i started to record the video, but this time the needle is up and down and all over the place and if you listen you will hear me turn on the heater blower but instead of the needle dropping it does actually rise, confused dot com, any suggestions anybody??
Posted: Wed Feb 15, 2012 3:31 pm |
tomd0801754 wrote: |
Cannot access your FB. |
okay thanks for the info i will go upload it to photobucket if i can, be back here in 5, thanks again.
Posted: Wed Feb 15, 2012 3:34 pm |
Posted: Wed Feb 15, 2012 3:43 pm |
also since this problem started i have now noticed a fast clicking like noise when i turned the ignition key but the clicking stops when the engine starts and i let go of the key, whats all that about, the clicking sounds like its coming from the steering column area or possibly round where the fuses are underneath the steering wheel, maybe related i dont have a clue, being a woman and all that lol.
Posted: Wed Feb 15, 2012 4:23 pm |
pugs are w**k i want my vtr back :0(
Posted: Wed Feb 15, 2012 4:29 pm |
Someone will know the cause, just be patient, it could be something simple
Posted: Wed Feb 15, 2012 6:50 pm |
lets hope so and thanks
Posted: Wed Feb 15, 2012 8:20 pm |
206DAG wrote: |
pugs are w**k i want my vtr back :0( |
Same company, same components as the pug's.
Posted: Thu Feb 16, 2012 2:53 am |
maybe so but a much better car all round, i really wish i had never bought this car, been one thing after another since day one.
Posted: Thu Feb 16, 2012 2:59 am |
Sounds like you've bought a bad one as I had a gti138 for 4 years and now have a gti180 and never had to fork out for anything other than wear and tear stuff, if you look after your car it looks after you ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Thu Feb 16, 2012 4:05 am |
Have a search for sensors. I'm pretty sure I saw a few topics on here about a faulty sensor causing the temperature guauge toa ppears as if it were overheating. I can't remember if it was the green coolant temperature gauge which goes into the thermostat housing or the other sensor that's near it but apparently it can causes issues. I'll have a trawl and see if I can find those topics again too.
Posted: Thu Feb 16, 2012 6:35 am |
yes mr hobnob i believe i have bought a right old pile of beep and i also use the phrase look after your car and it will look after you, no truer words spoken.
and thanks Taff i will go have another look, i just got tired of searching last night to be honest with you i will go have another look, i checked all the fuses includung the ones in the engine bay but there all good so as to what that clicking noise is and where it was coming from im not sure at all.
The best way to describe the type of clicking noise, you know when an indicator bulb goes you get a fast clicking noise inside the car, its a bit like that but not as loud.
Posted: Thu Feb 16, 2012 6:39 am |
CLICKY
ARRAN has a similar issue... will google now
