Posted: Mon Aug 27, 2012 3:03 pm |
Posted: Mon Aug 27, 2012 3:07 pm |
Posted: Mon Aug 27, 2012 3:10 pm |
Black is positive
Posted: Mon Aug 27, 2012 10:53 pm |
There is always the check it with a test light / test meter option
Posted: Tue Aug 28, 2012 5:33 am |
Remember the switch is after the lamp in the circuit.
If you connect to the live and then earth the light strip, it will drain your battery, if you connect in series it will only come on at half strength.
Posted: Tue Aug 28, 2012 10:31 am |
macca1411 wrote: |
If you connect to the live and then earth the light strip, it will drain your battery, if you connect in series it will only come on at half strength. |
means if i connect led directly to the wire socket the light wont turn off when
close the boot?
