Posted: Sat May 26, 2012 2:20 pm |
At least thats what i think i did, I was at the lights and gave it some beans, but missed second and crunched the gear ( ) and then nothing, engine fine but the gear stick was just loose and felt connected to nothing. I managed to get it over the side of the road and when i looked down into the engine bay, that bar that comes from the gear box has dislocated from the horizontal bar (looks like it has snapped)
Does anyone know if this is a gearbox out job or just replacing the linkage/selector arm as I can't see without removing everything how it's bolted to the gear box? Any help appreciated:)
Posted: Sat May 26, 2012 2:58 pm |
Is the gear selector a Y shape thing inside the gearbox housing?? Sure a gear linkage hasn't piped off or broken?
Posted: Sat May 26, 2012 3:06 pm |
linkages can be done from under the car, but if its a gear selecter fork that the shaft goes in to the box it will need to come out.
| I\'m Steve got a 2003 verve. | |
Posted: Sat May 26, 2012 3:39 pm |
Thanks for the replies
If i look down into the bay from the top there is a bar coming from the box sticking upwards, and the bar coming from the left hand side has snapped off....
Posted: Sat May 26, 2012 3:52 pm |
Just a linkage rod then. They are cheap Enof. If I remember right there's 2 long rods and 1 short rod. Your best to get genuine parts.
Posted: Sun May 27, 2012 1:26 am |
Has it snapped or just come off. Have you tryed clipping it back on.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Sun May 27, 2012 2:34 am |
I'm presuming you lost your 'Traffic Light Grand Prix'?
Posted: Sun May 27, 2012 4:23 am |
Very embarrasing scenario...... that'll teach me
